Any bad consequences from wrapping your ceramic coated headers?
Old Aug 12, 2006 | 02:56 PM
nonetooclose's Avatar
nonetooclose
Default Any bad consequences from wrapping your ceramic coated headers?
All,
I am thinking about wrapping my headers with heat covering to reduce the heat to the starter since it seems to be heat soaking (IE it gets voltage, but doesn't do anything - I do think I need a new starter though in addition). Has anyone suffered delitarious effects from doing this? I have TPIS longtubes on an 1985.
Richard
Old Aug 12, 2006 | 03:14 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I wouldn't. If you're going to change starters anyway, switch to the smaller, later version and then you should have plenty of room to put a heat shield on the starter. You can get them in the aftermarket or as I did, used a stainless heat shield for a 5" Kenworth exhaust pipe! Looks like it was made for it!
Old Aug 12, 2006 | 05:05 PM
vader86's Avatar
vader86
I changed to a smaller starter from 88-91 so I wouldnt have to worry as much about this issue.
Old Aug 12, 2006 | 05:43 PM
CFI-EFI's Avatar
CFI-EFI
Most header companies will void any warranty they may offer if header wrap is used. The extreme heat can change the metal, metallurgically and will accelerate oxidation.
RACE ON!!!
Old Aug 12, 2006 | 07:10 PM
LD85's Avatar
LD85
I have 3-years of warp on my ceramic coated hookers, no rust or degradation as of last weekend when I re-wrapepd them
Note,<<<<I do not drive the car in the winter.
Old Aug 12, 2006 | 07:51 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Also, an LT1 starter will give you even more clearance than a 88-91 starter, although you'll need to do some minor grinding on the aluminum case to fit your block. And your battery cables will take some work and rerouting to make them reach.
To Any bad consequences from wrapping your ceramic coated headers?
