'tts data master program not working properly"
Old Aug 12, 2006 | 06:46 PM
sxyvet's Avatar
sxyvet
Default 'tts data master program not working properly"
hi there guys,
just prevoiusly brought the tts datamaster program to suit my 1991 corvette!
also brought the ALDL cable to plug into toshiba laptop computer!
buy when i set up and try to scan/run program each time the program says it is not communicating with the ecm!
any ideas on what i am doing wrong, or is there some sort of problem, or may be i have the wrong ALDL cable or some thing?
thanks guys
glen
sxyvet
Australia
Old Aug 15, 2006 | 03:40 PM
Bozzy90210's Avatar
Bozzy90210
I just did the same thing. I needed to specify which comm port to use in order for it to work. Its under the Setup item in Serial Data Aquisition. The cable i use(moates) requires a specific USB driver. After that Im ouuta ideas, good luck.
Old Aug 15, 2006 | 08:09 PM
sxyvet's Avatar
sxyvet
hi there bozzy,
thanks for the reply/info!
i will look into it!
thank you
glen
australia
To 'tts data master program not working properly"
