87 Idle Surge Problem
Old Aug 12, 2006 | 09:47 PM
87FIREREDRAGTOP's Avatar
87FIREREDRAGTOP
Default 87 Idle Surge Problem
HI all, I have an 87 with a zz4 motor, BBK 58MM TB and 24LB Accell Injectors. I can't seem to get a good stable Idle. The only way I can stableize it is to remove the PVC valve from the valve cover. I have checked for vacume leaks and could find none(all new hoses). Also if I disconnect the MAF the idle flattens out, but I think this is because the computer is in limp mode. Could the ZZ4 be having problems with the PVC or do you think I am having other problems?
Old Aug 12, 2006 | 09:51 PM
DrEvil11417's Avatar
DrEvil11417
I'm having the same problem, but it's not a ZZ4, but it's still not stock. Do a search for minimum air, and let me know if you're able to get it set because mine is demonically posessed
Old Aug 13, 2006 | 01:49 AM
87FIREREDRAGTOP
It just dawned on me, the guy at the shop told me he set the timing at 10deg btc, it should be 6, think this could be the isue? I will reset it tomarrow.
Old Aug 13, 2006 | 09:11 AM
rodj's Avatar
rodj
I have a similar setup, had similar idle problems.
Advance changes made no difference.
Have you got headers?
Most of my idle problems went away when I fitted a heated O2 sensor as the headers run too cold at idle dropping the sensor out.
Also note , the BBK bleeds air directly into the plenum not through the holes in the base of the plenum direct to the ports like the stock setup does.
Has been mentioned as a issue by others sorting idle problems
Old Aug 13, 2006 | 10:34 AM
87FIREREDRAGTOP
I didn't use headers, just the stock center drops(might change later$$$). I also tried reinstalling the stock TB with no success. Any idea what the O2 cross counts should look like at Idle? This problem persists from cold to hot, open and closed loop. Well, I am going to go play with the timing anyway, couldn't hurt to have it right. Thanks
Old Aug 13, 2006 | 11:00 AM
tequilaboy's Avatar
tequilaboy
I think these idle surge issues all begin with open loop mixture problems, most likely a MAF calibration that has drifted or changed due to other mods. A Dirty or oily MAF wire, descreened MAF, Cold air kits, various intake mods, exhaust reversion, vacuum leaks, etc.
Once the rpm starts to cycle, the calulated load value also begins to oscillate. With load increasing as rpm is dropping, this causes both extra enrichment and reduced spark advance which further complicates things. Now both fuel, rpm and spark are oscillating with no end in sight unless conditions change, until either the motor stalls or the throttle is opened to break the cycle.
I have solved most of my idle issues with MAF calibration work in the chip and recently also preventing open loop enrichment vs load for load values 112 and below.
This has permitted more stable fueling at idle which has helped to smooth the surging.
I still have some issues with my startup fueling for warm starts (start up coolant 100F-140F or so). But its only a question of getting the correct mixture as a function of temperature and start up temperature for all conditions.
Consider things that can affect the mixute. Fuel pressure, vacuum leaks, MAF calibration, O2 sensor condition, intake mods. In many cases, I think tuning the MAF calibration is the only real answer.
Old Aug 13, 2006 | 11:41 AM
DrEvil11417
how do you fix the issie w/ the BBK?
Old Aug 13, 2006 | 11:52 AM
87FIREREDRAGTOP
As suspected, the timing correction cured nothing. OK, so I am at my end, I think I need a custom chip. Any Idia's I live in Nevada and don't know anywhere to have this done.
Old Aug 13, 2006 | 11:53 AM
goldeneye_vet's Avatar
goldeneye_vet
Old Aug 16, 2006 | 08:50 AM
87FIREREDRAGTOP
Do they have a web site or number? Also, why can I not read this post when I am logged in?
To 87 Idle Surge Problem
