Service ABS light
Old Aug 12, 2006 | 10:15 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Default Service ABS light
OK, My service ABS light it on.
1990 coupe L98
I disconnected the battery to clear the code. It went away.
Today I started the car, three weeks since I did so, and the light went back on again, and this time would not go off with a simple battery disconnect.
I noted that the front resivoir for brake fluid was a little light on fluid. I filled it, no difference.
I did replace the front speaker amps. Any wires up there I could have hit, screwed up. I did this amp replacment before the first time the light came on, and it went out.
If that's confusing here's the timeline:
1. changed the speaker amps (about three weeks ago)
2. Light went on (coincidence)?
3. disconnected the battery,
4. no problem, light went off, drove the car 300 miles, no light. Started and stopped the motor 4 times.
5. Started the car three weeks later
6. Light went on
7. Noticed the brake fluid was low, filled it, disconnected the battery
8. No difference
9. Light stays on.
10. Disconnected the battery overnight, not expecting anything.
Suggestions, comments?
Old Aug 12, 2006 | 10:54 PM
bogus's Avatar
bogus
hm... is the sensor hooked up to the master cylinder?
Old Aug 12, 2006 | 11:02 PM
jsup's Avatar
jsup
Yes, but it was lose enough that I could turn it 3/4 turn by hand. I did not put a wrench on it.
Should I tighten it more? How would I test it?
Old Aug 13, 2006 | 08:49 AM
jsup's Avatar
jsup
No one? Anyone? C'mon guys help me out!!
Old Aug 13, 2006 | 09:44 AM
jimmers's Avatar
jimmers
Mine just started doing the same thing.
To Service ABS light
