rear end gears
Old Aug 13, 2006 | 12:38 AM
hill's Avatar
hill
Default rear end gears
what if any is the best way to get the rear end gear size with out pulling the cover off the rear end. if i have something smaller than a 307 i am going to change it. i am thinking it is a round a 2:56 but have not pulled the cover to know for shur it is a 1990 non zr1
Old Aug 13, 2006 | 12:45 AM
JD'S WHITE 93's Avatar
JD'S WHITE 93
What does it tach at 80mph. A 2.59 will tach at 2000 rpm.
Jack it up get both rear tires off the ground and mark the driveshaft and spin the rear wheels by hand. Count the turns of the driveshaft. Or the easier way get the Rpo codes off the inside of your console door. Here are the codes
GM1= 2.59
GM3= 3.45
GT7= 3.33
GU2= 2.73
G44= 3.07
Old Aug 13, 2006 | 12:49 AM
vader86's Avatar
vader86
Look at the RPO codes, post any that start with "G"
You could also post the rpm you run at 70mph in OD.
Old Aug 13, 2006 | 12:52 AM
hill's Avatar
hill
the tack is not working i am trying to fix it it is an auto trans were would the rpo codes be
Old Aug 13, 2006 | 12:56 AM
JD'S WHITE 93
GM1= 2.59
GM3= 3.45
GT7= 3.33
GU2= 2.73
G44= 3.07
I added to my post now it should have everything you need.
Old Aug 13, 2006 | 09:08 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Its electro-etched into the bottom side of the diff housing.
Old Aug 13, 2006 | 11:03 AM
AKS Racing's Avatar
AKS Racing
If it is stock, a '90 coupe with auto trans should have had the 2.59D36. The '90 roadster with auto would have had the 2.73D36.
Aaron
Old Aug 13, 2006 | 06:23 PM
93ZF6's Avatar
93ZF6
Default RPO codes inside Glovebox door
Check the bottom of the glovebox door for the RPO codes, that is wher the codes are on my 93
Old Aug 13, 2006 | 07:01 PM
clf93lt1's Avatar
clf93lt1
console lid
Old Aug 16, 2006 | 06:41 PM
hill's Avatar
hill
the G codes are G44 & G92
Old Aug 16, 2006 | 06:42 PM
hill's Avatar
hill
the G codes are G44 & G92 & the D codes are
Old Aug 16, 2006 | 06:43 PM
hill's Avatar
hill
the G codes are G44 & G92 & the D codes are DL8 D3X D9B
sorry for the d-lay i have not had time as of late to check the board sorry for the tripple post
Old Aug 16, 2006 | 06:45 PM
vader86's Avatar
vader86
You have 3.07s
Old Aug 16, 2006 | 06:52 PM
hill's Avatar
hill
just looked under the rear end it is a 3.07 i guss i need to ad some hp to the motor it has none out of the hole and thanks
Old Aug 16, 2006 | 07:41 PM
MrNuke's Avatar
MrNuke
With 3.07s, even stock, your car should be fast out of the hole, IF you can get traction. With normal street tires you should be able to light them up easily.
Old Aug 16, 2006 | 08:17 PM
hill's Avatar
hill
it has nothing out of the hole cant even brake tork it just gets a little spin wail tring to brake tork thats is
Old Aug 17, 2006 | 08:34 AM
Casethecorvetteman
Must be good sticky tires or something's not right!!!
To rear end gears
Old Aug 17, 2006 | 06:30 PM
hill's Avatar
hill
well just put new tires on it BUT with the old hard balled tires the same thing checked the timing and its ok i have a new mac scanner and everthing apears to be ok have not checked fuel psi tho
Old Aug 18, 2006 | 12:10 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Dana/Spicer like a ****!
Old Aug 18, 2006 | 04:51 PM
hill's Avatar
hill
are you saying that is the type of rear the car has??
