Air Conditioner Problems
Old Aug 14, 2006 | 09:19 AM
kcdave51's Avatar
kcdave51
Default Air Conditioner Problems
I have a 1995 Corvette. My Air Conditioner works just fine except for the fact that it drains inside the car on the passenger side. I mean I could almost stock fish over there. I've tried to locate the drain tube from underneath, but with no luck.
Could someone please tell me where the drain is located so I can clean it out. I'm hoping it's just plugged. Also, I've tried to find a website with illustrations to help me find the drain on the system, but again with no luck. So if someone knows of such a site would you please post the address for me.
Thanks,
Dave
Old Aug 14, 2006 | 10:56 AM
Da Mail Man's Avatar
Da Mail Man
Thanks,
Dave
...while i don't have a 95, maybe i can help. elevate car on the passenger side and support it carefully. crawl under the car and examine the heater/ac box. there should be a "port/hole" very low on the box to allow condensation to drain from the evaporator. there may even be a "stain" or some other tell tail sign that water was once dripping from it. grab a Q-tip or some other blunt item thin enough to be placed into the drain and do so. ya don't want to do the "ram rod" effect because you could do some damage to the evaporator. don't look directly up at it as you will get a face full of water!..that should do it.
Old Aug 14, 2006 | 11:06 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
The AC/Delco part number is 1533111. It's a clear, plastic tube located underneath the vehicle on the passenger side. It's best viewed with the car on ramps or a lift.
You should be able to use a short section of wire pipe cleaner or a coat hanger to free any debris or mold in the tube. Be sure the tube is not crimped before attempting to clean out.
Old Aug 16, 2006 | 03:10 PM
kcdave51's Avatar
kcdave51
Default A Quick Thanks
Thanks for the response. I've looked underneath and found a pencil eraser sized hole on the bottom of the housing that was plugged. Thanks again.
Dave
Old Aug 16, 2006 | 03:11 PM
kcdave51's Avatar
kcdave51
Dave
Old Aug 16, 2006 | 03:34 PM
Da Mail Man
Dave
....spike that football!.........good going!.....figured that was the problem!
To Air Conditioner Problems
