My car was running somewhat well, when it just died....like it was out of fuel. Got it home, and started checking the usual things...has spark, has injector pulse, but no fuel pressure. Checked the pump...it runs fine. Pressure at the fuel filter.....pressure at the fuel rail inlet, but no pressure on the fuel rail? Could this be a FPR failure???? Car won't start...don't know why no pressure on the Fuel Rail. Any help would be appreciated....
I replaced a ton of stuff trying to track down a fuel problem and it ended up being the FPR, not very expensinve and it only takes about 15 minutes to swap out.
Pinch off the rubber part of the return line at the gas tank, and see if you can maintain fuel pressure at the rail. Disconnect the two injector fuses and see if you get pressure.
Similar thing happened to me. No fuel pressure at all.
Turns out the fuse blew that I had. I installed a walbro 255 lph fuel pump with the Racetronix "hot wire" kit. Switched the fuse right behind the alternator and fired right up.
tried this, and it made no difference at all.....need some more ideas.....
Yep, got the same setup as you, but the fuse is fine....pump runs, pushes out a ton of fuel at the output hose at the tank, plenty of fuel at both sides of the filter, nice stream at the inlet of the rail, but just kind of dribbles out at the shrader valve......
