92 starting problems
Old Aug 14, 2006 | 08:05 PM
catfan123's Avatar
catfan123
Cruising
Default 92 starting problems
I just purchased a '92 six speed with 62,000 miles. The car ran fine until a few weeks ago.
The last few trips after I shut the car off, it will not start back. It has stranded me three times. Eventually the car will start back. Sometimes in fifteen minutes, sometimes it takes hours. Once the car starts ,the security light will flash in tandem with SYS on the speedometer. At this time the speedometer works, but the rest of the gauges seem frozen. Even the gas gauge does not work. The ASR light comes on as well. When the car starts normal, everything is fine. I have had the car into a dealer as well as a independent shop. The dealer found nothing wrong, The shop replaced the battery.
This is my first Corvette and any help would be appreciated.
Old Aug 14, 2006 | 08:22 PM
bogus's Avatar
bogus
C4 Guru - Reading CCM Codes, 1992/93
Try that... I am curious what codes are stored.
It will also pull codes from the EBCM - the ASR/ABS brain.
Read and digest.
Old Aug 14, 2006 | 08:29 PM
catfan123's Avatar
catfan123
Cruising
Default Thanks
Thanks I'll try anything.
Old Aug 14, 2006 | 09:50 PM
jfb's Avatar
jfb
What do you mean that the car won't start back up? Do you mean that the starter motor won't crank the engine, or that it cranks but the engine won't catch and run? You need to better describe your problem.
Old Aug 18, 2006 | 04:12 PM
catfan123's Avatar
catfan123
Cruising
The engine will turnover, but will not run
Old Aug 18, 2006 | 04:19 PM
catfan123's Avatar
catfan123
Cruising
Just got back from vacation. The starter engages, the engine will not catch and run. It will sputter but never catch hold. My concern is the flashing security light as well as SYS, when it does finally start. The car runs great once it starts. But if those two lights are flashing when I turn it off, it will not restart for a period of time. Very frustrating.
Old Aug 18, 2006 | 04:21 PM
catfan123's Avatar
catfan123
Cruising
If the check engine light is not flashing, will a code still show up. My local mechanic says it will not?
Old Aug 18, 2006 | 04:56 PM
bogus's Avatar
bogus
You can get stored codes out. The light does not need to be on.
Old Aug 18, 2006 | 06:12 PM
ccford's Avatar
ccford
Here's a thread to follow:
http://forums.corvetteforum.com/show...&highlight=ECM
Search for other threads with ECM and ECM communication.
When the security and SYS lights flash it means the serial communication with the ECM is having problems. When this happens, the ecm doesn't pulse the fuel injectors when you attempt to start. The engine may strart and run for an instant then die. I'm hoping mine will be fixed by cleaning the grounds to the engine block, above the oil filter. Keep us posted and I'll do the same.
Joe
Old Aug 18, 2006 | 09:33 PM
Fabinatl's Avatar
Fabinatl
My 92 did that and I ended up replacing the ECM. Started right up and has run ever since. Codes went away also!
Old Aug 19, 2006 | 07:14 AM
RRT vette's Avatar
RRT vette
Originally Posted by bogus
Read this as Bogus posted. If the SYS light is flashing there is a stored code that needs to be attended to first.
Old Aug 19, 2006 | 08:57 PM
vetterlatethannever's Avatar
vetterlatethannever
as this is the same problem a friend of mine is having.
Old Aug 20, 2006 | 06:11 PM
catfan123's Avatar
catfan123
Cruising
I will begin the search for an ECM on Monday. Is this replaceable for the novice or should it be handled by mechanic?
Old Aug 20, 2006 | 06:12 PM
RRT vette's Avatar
RRT vette
Located above the battery. YOU CAN DO IT!
To 92 starting problems
