Est. Temp. Drop With Transmission Cooler
Old Aug 15, 2006 | 10:59 AM
Da Mail Man's Avatar
Da Mail Man
Default Est. Temp. Drop With Transmission Cooler
greetings,
i have been reading posts on transmission coolers and have a simple question.
if a transmission cooler was added BEFORE the input to the radiator, what could be expected (if any) as a water temperature drop in the radiator since the transmission fluid is being "cooled" before hitting the transmission?
**i know that there are a lot of variables so actual temps don't apply, just the difference in number of degrees as an ESTIMATE or suspected guess of drop (if any).......thanks.
Old Aug 15, 2006 | 03:16 PM
toptechx6's Avatar
toptechx6
That's definitely a different approach, the air to air coolers are normally added after the radiator as the fluid returns to the transmission. I'd be surprised if you would get much drop in radiator or engine temp but it is just a guess based on the fact that I'm aware of no difference in normal operating temps between automatic and manual cars. Maybe someone else has more factual information.
Old Aug 15, 2006 | 03:25 PM
Da Mail Man
....well, the way i see it is that if one runs a 180* t-stat, the transmission fluid temp has to be way above that. the radiator will be trying to cool and maintain a temp close to the t-stat rating and if you eliminate the extra heat from the transmission, it would run considerably cooler, or at least not have to "strain" to maintain a reasonable temp and to fight off that all to familiar increase in h20 temp from sitting in traffic or "spirited driving". the trannie should run cooler by the mere existence of the cooler and the radiator should be "cooler" or at least be able to "maintain" a slower rise in temp.
**this post is strictly for automatics**
Old Aug 15, 2006 | 03:40 PM
toptechx6's Avatar
toptechx6
It is an interesting concept, let me know your results if you give it a try!
Old Aug 15, 2006 | 03:51 PM
Da Mail Man
not in the too near future yet!......at any rate, look at it this way; the temp of the transmission fluid has to be well over 200 degrees and with the trannie cooler in the "input" line to the radiator, the radiator should run cooler or cool down faster not having to try to cool the additional high temps of the trannie, further, it will have less of a job to cool the engine since nobody runs a 200* t-stat. win-win situation as i see it!
Old Aug 15, 2006 | 04:29 PM
Blownfuel1's Avatar
Blownfuel1
Some tranny shop's over the years have advocated putting the aux. cooler on the inlet side of the radiator's cooler with the claim that the Aux. cooler COULD cool the fluid too much, and that running it through the radiator last would ensure a sufficient operating temp. Although I suppose it is conceivable, I've never had the problem of a tranny that ran too cool (wish I could get that lucky!), and I think the theory is ! As far as your original supposition, I'm not sure it should make a difference, if the aux. cooler is on the outlet side of the rad., wouldn't it cool the tranny fluid further than than the radiator did, therefore supplying cooler fluid back to the tranny, which SHOULD lower the tranny operating temp., and therefore the outlet temp as well. Each cooler should remove a specific amount of heat, the only variables should be in the efficiency of the cooler due to location, airflow, etc...
Old Aug 15, 2006 | 04:40 PM
Da Mail Man
.....ohhh here we go!.....look, ya don't have to get nasty about it! it is easier to maintain the engine temp by pre-cooling the trannie fluid before it gets to the radiator thus making the radiators' job easier.
.....the radiator will maintain the engine temp AS WELL AS the temp of the fluid going back to the trannie. the engine will run cooler and the trannie will have a fluid temp comparable to that of the radiator h20.
so, if you want to comment, please do but just leave the " " image out from the post as it is not necessary. nobody's right when everyone has their own opinion.....
...yes, we are talking about a TRANSMISSION cooler but, the way i have stated it, will benefit both engine and trannie IN MY OPINION
Old Aug 15, 2006 | 05:43 PM
Aardwolf's Avatar
Aardwolf
Here is a link where the cooler is before the radiator:
http://www.ws6transam.org/transcooler.html
If I were to add a cooler, I would plumb it in after the radiator though. I would want the max. cooling I could get. You don't want your trans. tempature any where around engine temp. it should be much lower. 175°ish for long life. To cool both the coolant and trans. more, a better radiator would do more then a small trans. cooler. Just my two cents.
Old Aug 15, 2006 | 05:46 PM
Da Mail Man
...i sorta agree in part......the temp of the t-stat and the radiator should govern the temp of the fluid returning back to the trannie..radiator temp at about 180* is not too hot for trannie fluid returning....
Old Aug 15, 2006 | 07:08 PM
Blownfuel1's Avatar
Blownfuel1
Mail man, I think you miss understood me, the only thing I think is BS is the idea of the cooler cooling the transmissions too much. No offense was intended, I just don't think any of these little aftermarket coolers are going to remove that much heat. I wasn't attacking your idea, just the concept that there are all these cars on the road with tranny's that are running too cool cause they put aux. cooler on it. The whole first paragraph was basically just for info, only the second one was actually addressed to your idea... and it was only supposed to be some added info to think on. I don't actually know if it will work better, the best way to find out is to try it both ways on the same car and see what results you get. Also, I'd get one of those little laser non-contact temp. probes to check cooler inlet and outlet temp's, etc. I just picked one up at Harbor Freight that's about the same size as a car alarm remote for $9.99, and it seems to work real well.
Old Aug 15, 2006 | 07:12 PM
Da Mail Man
........uh, well, maybe i barked and bit too fast as i really did misunderstand so, publicly, i will apologize for the crass retort....
Old Aug 16, 2006 | 10:28 AM
Blownfuel1's Avatar
Blownfuel1
No apology necessary, but thanks! Just a simple misunderstanding. As it's been said many times before, it's sometimes hard to discerne (sic) someone's intent through just the written word. On a lighter side, I thought Mail men and Dog's ("i barked and bit too fast!") wern't supposed to get along!
I'd be real interested in seeing the results if you do get around to trying the cooler install prior to the rad. ie. before and after coolant temp's, and the contact temps on the tranny cooler lines.
Old Aug 16, 2006 | 10:48 AM
Da Mail Man
...grin...well, i am not a mail man but in the legal profession. i also know of mail carriers that bring treats for the canines and it works out fine. the dogs look forward to the visit and the carriers take time out to play with mans best friend,....as far as the "pre-cooler", if you can cool fluids before the radiator, it will be easier to cool everything else that travels through there......look at it this way, if the interior of your car is 145* and you turn your ac on, will it not take more time and "effort" to bring the temp down to say 75* then if your interior is only 10*....
......i know te ac example is a bit much but, i think you van catch the drift.......i will eventually get around to doing this in late fall.
Old Aug 16, 2006 | 11:02 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
I’d be very surprised if you noticed any difference at all. As toptechx6 said in the first reply, there is no difference in operating water temps between the manual and automatic cars. So, the trans fluid going through the radiator probably isn’t the limiting factor in your cooling system.
Old Aug 16, 2006 | 11:09 AM
Da Mail Man
...i strongly disagree. i did this with my 81 vette (auto) and it ran cooler and the engine cooled off quicker and boy, did the cooler get hot!......
...***i am ONLY addressing my experiences with the cars i have "pre-cooled" and automatics, NOT water temps between autos and manuals.
.....pre-cooling is all that much better because it benefits both the engine in faster cooling and possibly more regulated cooling, trannie - as it reasonable assures that the return fluid will be cooled enough before returning as that fluid is not "t-stat" regulated, and radiator in the effort and efficiency it takes to cool excessive btu's from the system....
....as long as the t-sat was working (i use a 180*), i believe that one should be reasonably assure that the return temp of the trannie should be somewhere around the rad temp.........i thought that someone said that "too cool was bad(?)".....
Old Aug 16, 2006 | 11:15 AM
RollaMo-LT4
Well, it's not a big cost item to test out. If it works great, if not you haven't wasted too much. Guess it's worth a shot. Be sure and let us know the results though.
Old Aug 16, 2006 | 12:07 PM
Steel Breeze's Avatar
Steel Breeze
It is only logical, that the trans. and engine will run a little cooler (depending on air flow). But lets look at it closer. You put a cooler before the the radiator trans. fluid cooler, then stick the cooler in front of the radiator (physically). Well the air passing throught the cooler, then back right into the radiator, adding heat soak. Much like the AC condenser. but we are getting into numbers here, and air flow. If you have enough airflow past the cooler, and condensor. It is going to run cooler, its just a natural fact. Keep in mind the trans cooler in the radiator, could be a trans warmer too. Say the trans is at 180*, and the engine is at 228*. The cooler then becomes a warmer. Much like the oil coolers that come stock on some C4 models. My car has one, as a matter of fact.
Cooling is an interesting concept in our C4's. That is why I am working on this two speed super fan. I will be able to program at what temp it comes on. Then high speed is activated, pulling around 3500-4000 CFM. Its in the works, but I have alot going on right now...
Any who, hope you come out on your cooler. My educated guess is, that the trans will in fact run cooler. The engine, I just don't know... Hope this helps, and remember, it is just my oppinion...
To Est. Temp. Drop With Transmission Cooler
Old Aug 16, 2006 | 02:11 PM
Da Mail Man
........ .....not to sure of the "heat-soak"..as it will all depend on where ya mount the cooler and for the most part, the cooler will take up a fraction of the area in front of the radiator/condenser if mounted there.....as long as the radiator doesn't over heat from a closed t-stat or other engine problem, there should be cooool all the way around ........grin
Old Sep 6, 2006 | 10:11 AM
Aardwolf's Avatar
Aardwolf
This topic relates to your topic:
http://forums.corvetteforum.com/show...mission+cooler
Old Sep 6, 2006 | 10:50 AM
Da Mail Man
.......while i had only a chance to scan the link you sent, i stand by my opinion. i run a 180* t-stat and the trannie fluid going into the radiator is no doubt hot. the trannie fluid is dependent on the h20 temp to cool it down before returning to the trannie.
1) if i have a low temp t-stat (180), i have a better chance of cooling the trannie fluid down when it circulates in a +/-180* coolant environment then in a 220* coolant environment.
2) if i cool the trannie fluid down with a cooler on the INPUT side of the radiator, my t-stat/radiator would not have to get rid of so much heat (a lot absorbed from the trannie fluid from the heat transfer to the h20) and may keep the h20 temp down a bit and so the engine too.
if i placed the trannie cooler at the OUTPUT of the radiator, not only would it have to contend with cooling down the temp of the water which could be as high as 220* absorbed by the trannie fluid but, also the heat of the trannie fluid itself that was not sufficiently cooled by the radiator as well..........defense rests....
