Replacing headliner
Old Aug 15, 2006 | 03:15 PM
wrlwynd's Avatar
wrlwynd
Default Replacing headliner
I have to replace the headliner in my 94 coupe. Does the healiner just pop out of the fiberglass top or are there any screws/moldings that I have to remove on the side?
Old Aug 15, 2006 | 03:54 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Check back a couple of days on the forum, someone else had a similar question, general forum "headliner sagging".
Old Aug 18, 2006 | 07:58 PM
Da Mail Man's Avatar
Da Mail Man
........i took one out of a mid 90's targa top and found that it was securely glued in.
....i had a hell of a time removing it in 1 piece. i retro-fitted it into an 88 targa (after rebuilding the back) with clear bronze top to reduce the residual heat from top here in florida.
Old Aug 18, 2006 | 08:32 PM
Fasterer's Avatar
Fasterer
My 85 came out fairly easy. one I got one corner started it poped out. I found no glue one the side toward the targa top. The bow in the material seems to hold it in just fine.
Old Aug 18, 2006 | 09:08 PM
LD85's Avatar
LD85
Take a thin putty knife and run it around the perimeter slowly prying upward until you slowly separate the old top from the fiberglass,
Thne scrape the fiberglass very clean
Then wrap the new headliner round the old fiber lining leaving only @ 1 inch around the "glue side" of the liner.
Then spray the adhesive onto the fiberglass and press the new liner on. It sticks quickly so aim well!
Da Mail Man
.....well, ya lucked out!.......the one i took out had glue all over it. i think for some years they used some sort of "adhesive strips".i am unaware if the oem headliners were of the "pop-in" type...
To Replacing headliner
