1988 heater core
Old Aug 15, 2006 | 07:48 PM
oneonone's Avatar
oneonone
Default 1988 heater core
Alright how hard is this to do. Can anyone post directions on how to do ??????? Thank's
Old Aug 15, 2006 | 08:13 PM
86PACER's Avatar
86PACER
Page 1
Page 2
Page 3
Page 4
More
Old Aug 15, 2006 | 08:22 PM
Aardwolf's Avatar
Aardwolf
I clicked the pages but my heater core didn't get changed!
Old Aug 15, 2006 | 08:40 PM
oneonone's Avatar
oneonone
That didnt look good....Someone told me they found an easy way. But now i cant find him...
Old Aug 16, 2006 | 12:39 AM
jimmers's Avatar
jimmers
You can pm Jet-Jock. He has a pdf that he made detailing the process. It's not hard to do, its just time consuming and frustrating.
Old Aug 16, 2006 | 12:54 PM
Clay Assassin's Avatar
Clay Assassin
I did my '89 last year.
The job was pretty easy, with the exception of the last two top bolts on the heater box. I pulled the right one, and left the left one in so I didnt have to re-install it. It does take a while.
I also snapped the little platic door gizmo that hold the motor lever to the door inside the box when I put it back together, and had to do it twice!
Old Aug 16, 2006 | 04:47 PM
oneonone's Avatar
oneonone
Now just a few weeks ago when i asked about a tune up? Everyone was saying learn how to work on ur own car. And I only get 3 response's on this?
Old Aug 16, 2006 | 11:56 PM
RonsRed88's Avatar
RonsRed88
See my post in this thread:
http://forums.corvetteforum.com/show....php?t=1216678
It's not as bad as it seems. Definitely DON'T take your dash apart.
Ron
Old Aug 17, 2006 | 09:58 AM
Rich Silvestris's Avatar
Rich Silvestris
St. Jude Donor '05
The article posted shows that you have to remove the breadbox and the lower carpeted dash section on the left. Not so! I did mine a couple of years ago, and I did remove the top of the dash. I prefer looking at the world right-side-up, so that helped. It also provided another angle of approach for the fasteners on the ECM and the core housing.
If you can find a magnet for your 7mm socket, that would be a real plus. I couldn't, so I used a dab of grease to hold the little bolts in the socket during installation. The toughest reach is for the bolts on the top of the core housing, and I can relate to the frustration that led to Clay_Assasin's approach Keep reaching though, all the unseen bolts are 7mm, (so now you can save time trying different sizes). Once inside the core housing, you'll be further frustrated by the clips that hold the core into it. They aren't as bad as the housing bolts themselves, but you just don't need another hurdle at that point.
I took out the passenger's seat and put a worklight in the hatch area pointed at the dash. I wish I had taken the time to cover the seat mounting bolts (ouch). I wish I had raised the car up a bit (Ooh, my back), and I wish I had taken the time to remove the top to ease some of those twisted up positions I had to get into.
Take note of the order of removal of the various parts. The manual has an error in it for the assembly, and I got stuck back-tracking. (I think it was relating to the heater door positioner and the ECM.) The manual also has you remove the flexible duct that routes the defroster to the passenger's door. It's a pain to get back in, and it is only necessary to free it up at the other end and push it out of the way. I wish I'd done that too.
In the end, you will be battered but not beaten. This is do-able, and it is strictly mechanical (no electronics). It is not a simple evening repair. It took me three nights to do it and two more to recover. I say go for it. Afterall, everybody should have to do the crap I had to do!
Old Aug 17, 2006 | 10:34 AM
Muffin's Avatar
Muffin
Everyone has their own tale to tell about heater cores. Mine is simply this: The General started with a heater core and built a car aound it. I will pull and rebuild an engine before I will tackle another heater core, on second thought, make that two engines and a transmission.
Old Aug 17, 2006 | 10:51 AM
jimmers's Avatar
jimmers
C'mon its not that bad!
Old Aug 19, 2006 | 12:08 AM
Movnviolation's Avatar
Movnviolation
Put your car on ramps or something to raise it up. Also go to Sears or another tool place and get a flex 1/4" drive extension. Sears also has a set of 1/4" accessories that include handy little tools.
The job is doable but frustrating!
Old Aug 19, 2006 | 03:31 AM
Tourney3p0's Avatar
Tourney3p0
I did the heater core on my 88 without taking the dash apart. Take out the passenger seat, lay down a blanket (so you don't have the studs grinding into your back), and get to work. Actual working time was about 2 hours, start to finish. But I took quite a few breaks in between because I got tired of holding my arms up above me.
The most difficult part is taking out the bolts around the box that contains the heater core. I believe that's most likely why they say to take the dash apart, because it can be tricky to get to some of the bolts. I only ended up having a problem with one of them, and a swivel took care of it. I had absolutely no problems at all except for that, and the bolts are easy to feel out with your fingers.
To 1988 heater core
