The web site posted above is for 84-89. rcr103 has a 91.
When you say it blinks, are you saying the LCD display completely blanks out then comes back to life. Or does it just dims alittle and gets bright again.
My 91 dims then gets bright then dims again. I don’t know what the problem is on mine. I am thinking it is a bad ground. Sorry I can’t help but I will bump this post because I am curious.
From: The land of 10,000 lakes ,Minnesota 89 coupe 6speed with 383 and 89 roadster 6speed bonestock with XXX low miles
My 89 coupe had a flickering in the dash a few months ago I changed my battery (it had not failed yet just a little PM) while I had the battery out I could see a terminal that grounded to the frame and it had corroded so I cleaned it and the screw/bolt and added some copper coat and the flickering is gone now!
It goes completley off and back on so fast you can't read it all the time.
