A/C clutch grease?
Old Aug 16, 2006 | 03:42 PM
phat87's Avatar
phat87
2021 C4 of the Year - Unmodified Finalist
Default A/C clutch grease?
First thanks to all admins and players for making this amasing site work.
My 87 is throwing "grease" from the A/C clutch pulley up onto the inside surface of the hood and down around the monting bracket. It's a situation which is slowly getting worse.
So..is this serious and is it an expensive fix?
Thanks in advance for any an all replys.
phat sew
Old Aug 16, 2006 | 03:53 PM
rightofway's Avatar
rightofway
the problem is that the front seal on the compressor has gone out, what you are seeing is A/C oil
easiest thing to do is replace the compressor
you are also slowly losing the charge on the system and it will quit all together.
i have heard that the oil also will damage the fiberglass
Old Aug 17, 2006 | 11:21 AM
bowtie350_428's Avatar
bowtie350_428
Are you sure it is not that you are melting your rubber damper on the A/C clutch? Do you also have a burnt smell of rubber or electrical smell?
If the compressor is leaking oil, it would not look like axle grease. It would look like it is collecting dust. If you are melting the rubber damper, then you would see it thrown around the hood.
Old Aug 18, 2006 | 09:09 PM
phat87's Avatar
phat87
Default A/C challenge
Thank you gentlemen.. No smell of rubber but I'll do a closer examination of the material.
Thanks phat sow
Old Aug 18, 2006 | 10:40 PM
89vert's Avatar
89vert
It is your clutch. In the picture you see the part on the right. This is the magnet that pulls the clutch in and turns the compressor. As you can see it is copper color. It should be black. The stuff you are finding is the black epoxy they use to seal the magnet and is melting and flying out of the magnet. Sorry I know it is not the correct terms for the material but I hope you understand. Hope this helps. Tim
Old Aug 18, 2006 | 10:47 PM
rightofway's Avatar
rightofway
i've seen the melted plastic before but never seen it come completely off.
To A/C clutch grease?
