Error Code 63
Old Aug 16, 2006 | 04:41 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Default Error Code 63
Had the car scanned and came up with CODE 63. 1990 L98
Can someone tell me what that is.
The book says ABS relay, however I took the relay out and tested it (applied power based on the schematic on the side of the relay) and the relay clicked. So I assume it works.
Can someone please tell me what it is?
Thanks,
Old Aug 16, 2006 | 06:46 PM
86PACER's Avatar
86PACER
Scroll down to where the code chart is on the link below:
Codes
What code(s) does the car give you when you manually ground the A and B terminals of the ALDL connector?
