how do i clean injectors?
Old Sep 8, 2001 | 12:31 AM
jackyy's Avatar
jackyy
Default how do i clean injectors?
do i bring it to the dealer or midas..or can i do it myself in little time...
thanx
p.s i think i should do it cause when im at a stop light it idles funny..nothing to panic over but it seems that when its in neutral its a more stablt idle..or else the car is running SUPER!!
THANX
Old Sep 8, 2001 | 04:15 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: how do i clean injectors? (jackyy)
To have them reconditioned and flow tested for $80 send them to Rich at Cruzinperfromance (link on my site). He does a great job with 2-day shop time. He will even blue print em for $5/injector replaced.
Your problem may be the IAC, TPS or something other than the injectors.
Old Sep 8, 2001 | 11:05 AM
jackyy's Avatar
jackyy
Default Re: how do i clean injectors? (65Z01)
the iac was replaced already...plus i just the tune up its just when im at a red light it idles at 400-600 and i feel it could let go
thanx
Old Sep 8, 2001 | 12:32 PM
David-F's Avatar
David-F
What year car do you have, you may have replaced the IAC but has the throttle body been cleaned. Build up on the throttle plates can cause all kinds of idle problems also most cars will idle at or around 600 rpms from the factory. If when you first come to a stop it dips real low I would check the throttle plates. Also if you have a 89 or newer unless you remove the injectors and have them sent out were they can sonic clean them there is a chance of shorting out the windings in the injector if you try to flush them with injector cleaner through the fuel rail, the coils of the injectors are gas cooled and a harsh cleaner can wash the insulation of the windings and short them out.
David Fulcher
Old Sep 8, 2001 | 06:41 PM
jackyy's Avatar
jackyy
Default Re: how do i clean injectors? (David-F)
the throttle body was cleaned....what kind of cleaning do the injectors need...cause the place here said its something they have thats like a vacuum and its the latest thing..maybe u can tell me the name of it so i can tell them
thanx
Old Sep 8, 2001 | 09:49 PM
lowflyer's Avatar
lowflyer
Cruise-In I Veteran
We have this machine that runs cleaner through the injector rail and through the injector. Everytime I use this thing you can really notice an improvement in fuel pressure and idle quality. Its not uncommon to see an increase of 1 to 2 PSI increase. You should see the gunk that comes out too!! I think Midas and some of the other repair shops use them, but it will not do as good a job as removing the injector and having them rebuilt to blueprinted specs by a competent shop. On the other hand, that method will not clean the crud from the injector rails, fuel pressure regulator and the return line, which is usually the cause of some drivability problems. Just my 2 cents. Good luck, and if you're ever in Orlando, we could run your car through it....for $89.99 or course
Old Sep 9, 2001 | 01:06 AM
jackyy's Avatar
jackyy
Default Re: how do i clean injectors? (lowflyer)
so then i can go to midas and be confident that they do a good job?
thanx
Old Sep 9, 2001 | 09:19 AM
CaneinBatonRouge's Avatar
CaneinBatonRouge
jackyy, if the shop is talking about the motor vac system, in my opinion, I would do it. We currently have one at our shop doing demos and on my 87 it made a world of difference. The motor vac cleans not only the rails and the injectors, but decarbonizes the intake, valves and combustion chamber. When the Snap-on guy first brought the machine in and told us the price($4400 :eek: ) I was really skeptical, but after using it on my car I am a believer. :seeya
Old Sep 9, 2001 | 12:21 PM
jackyy's Avatar
jackyy
Default Re: how do i clean injectors? (CaneinBatonRouge)
ok cool thanx
Old Sep 9, 2001 | 06:58 PM
callaway95's Avatar
callaway95
try a bottle of Chevron Techron fuel injector cleaner first to see if it helps...... I was having a lean problem, resulting in less power. I changed a few things, but also added a bottle of Techron & got some power back..... for a few $, it's worth a try
Dave
Old Sep 10, 2001 | 12:14 AM
jackyy's Avatar
jackyy
Default Re: how do i clean injectors? (callaway95)
i was told by a mechanic in a vette shop never to put that stuff inside..it does more harm than good
thanx
Old Sep 10, 2001 | 01:40 AM
black85's Avatar
black85
Are you talking about fuel additives in general or specifically Techron? I heard it is approved by almost every manufacturer. It is recommended by Porsche and Volvo. Also, I bought mine at the Chevy dealer. If anyone knows anything wrong with using Techron I would be very interested to know! I was told it is pretty much harmless when used as directed in just about anything.
Old Sep 10, 2001 | 07:47 AM
93vetteguy's Avatar
93vetteguy
Default Re: how do i clean injectors? (black85)
I have heard from several Chevy mechanic and they all recommend Techron. :cheers:
Old Sep 10, 2001 | 07:28 PM
Hutch's Avatar
Hutch
Concur. I had a Motor Vac done about a year ago and it really did make a noticeable difference in throttle "crispness" (if that makes sense). Seemed to be kinda short lived so I guess its time for another visit to the shop.
Old Sep 10, 2001 | 09:54 PM
callaway95's Avatar
callaway95
Default Re: how do i clean injectors? (gs633)
Techron IS the only GM approved fuel injector cleaner.... not only is in in their routine maint. book, but when I was having trouble, I called Doug Rippie Motorsports (to order an AFPR) and they said to definitely try the Techron first.... I've used two bottles now & no ill effects (only better effects!)
Dave
Old Sep 10, 2001 | 10:23 PM
jackyy's Avatar
jackyy
i made an appointment at the vette dealer for tomorrow...they said what they do is the have a bottle and disconnect the fuel pump and make the engine run with this stuff and then reconnect the fuel pump...he said thats the best for the vette since the fuel injection system is different from other cars
thanx
Old Sep 10, 2001 | 10:42 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
I would pay attention to David F.
Really
To how do i clean injectors?
Old Sep 10, 2001 | 10:46 PM
jackyy's Avatar
jackyy
Default Re: how do i clean injectors? (PeteL)
i spoke to 3 different vette shops and each of them gave me the same answeras to how they clean them
thanx
Old Sep 10, 2001 | 11:11 PM
PeteL's Avatar
PeteL
While you have not answered the question, I found that your have a 91 Corvette?
I would listen to David F, if he says you could get in trouble with cleaning in this manner it may be expensive not to listen. David F knows some stuff about these cars.
Good Luck, it's your choice. Might ask those lads if they will warranty those injectors after the service for the next 5,000 miles or so. Also might be a good idea to check hot and cold resistance of each injector before the test. Just some suggestions. Good Luck.
Old Sep 10, 2001 | 11:39 PM
jackyy's Avatar
jackyy
i wasnt trying to be a smart foot in any way.but its just that i asked midas and they said they do it with a revolutionary machine(vacumm or something)..and then i asked 3 different vette places..2 in florida and 1 here in canada and both say the same thing...but now your getting me scared...
thanx
