Valve stem type
Old Aug 17, 2006 | 04:46 PM
Bilyk's Avatar
Bilyk
Default Valve stem type
Which valve stem seal type should i use? It's an 85 with about 60k miles on it
I was thinking regular hats for the exhaust and positive type for the intake
Old Aug 17, 2006 | 07:05 PM
Bilyk's Avatar
Bilyk
Anyone? I wanted to do the job tonight
Old Aug 17, 2006 | 08:37 PM
colonboy14's Avatar
colonboy14
From: University of Alabama at Birmingham School of Dentistry
I used positive seals on all the valves on my TPI, no problems so far.
Old Aug 17, 2006 | 08:54 PM
cmontel727's Avatar
cmontel727
I used the fel-pro valve seals with no problems. No more embararssing start up smoke!!!
Old Aug 17, 2006 | 09:01 PM
Fasterer's Avatar
Fasterer
Went with Fel Pro on mine and no more start up smoke.
Old Aug 17, 2006 | 09:18 PM
Bilyk's Avatar
Bilyk
Well what type were they?
The oe seals are little o-rings for the intake and rubber hat looking things for the exhaust, I believe. Is this what the fel-po set comes with?
The positive sealing ones are smaller and have metal rings as part of the seal to keep the tight against the stem. No oil runs down the stem, but at the cost of marginally faster valve guide wear.
It's an old motor, and stock, so I'm at a loss at to which ones I should use.
To Valve stem type
