92-96 will work if you swapp the LCD with one from a 90-91 there are also a few warning lights that are different.
What is the problme you are having with yours?
Well to start with the tach pegs and goes bac to 0,with or without the filter,the digitals blink on and off rapidly,and there is no illumination in the back,with or without lights on.
Any thoughts?
Randall
Any thoughts?
Randall
Tach makes it sound like a Cluster problem..
The Backlighting could be a bad Photo sensor located on the DIC to the right of the Cluster. The blinking LCD could be a bad CCM, infact all (except the tach issue) could be CCM related.
You should be able to find a cluster on eBay for a reasonable price
Ok,I understand that a 92 -96 cluster does not work with a 91 ccm,if I get a 92 -96 ccm what will I have to do to make it work?
Thanks for any help.
Randall
Randall
to make a 92-96 work you need to:
Swap the LCD from your 90-91 cluster.
you also need to cut and modify some of the Circuit board routing to work the correct Idiot lights.
What if change out the ccm also?will i still have to reroute the circuit board?
Thanks,
Randall
Thanks,
Randall
the 92-newer CCM will not play nice with the 91 ECM, No the 92 ECM will not work. Now if you bought a 92 cluster, swapped in your LCD and installed it to VERIFY it will fix the issue, then you do not need to chnage the Circuitboard wiring. those cluster mods for the Circuit board are just to Light up the correct Idiot light. For example when you turn the key, the Seat belt light, might be the brake light instead.
O K thanks,I bought a 94 cluster on E bay for $25 it looks good we'll how it works.
Thanks,
Randall
While I'm waiting on the new cluster I started checking the old cluster board. Found 2 blown fuses and a bad resistor.Replaced all ,pluged in the cluster,turned on and the digital lights up but it is blank,clean screen,everything else works.ccm? if so how do I reprogram another one,and does the ccm control the a/c control module?
Thanks for any help
Randall
Nothing on the digital display lights at all? when the key is first on there is a blanking control, lights all the LCD pixels.
Sounds like it could be the CCM (dealer item only)
what is wrong with the AC?
Yes the screen lights up but there are no numbers or anything,just a blank orange screen,for the a/c the buttons are not controlling the functions,seems to be stuck in auto.
Randall
