NO HIGH RESOLUTION PULSE FROM OPTI ,code 36 ??
Old Aug 18, 2006 | 01:49 PM
mjfox's Avatar
mjfox
Default NO HIGH RESOLUTION PULSE FROM OPTI ,code 36 ??
I scanned my 1992 corvette got a code 36 .Did the flow diagram from the gm manual comes up as NO HIGH RESOLUTION PULSE FROM OPTI
not being received by ecm.I do vave 4.7 volts coming from ecm to opti .Is there a repair for this or do I have to replace the entire opti.Can It be cleaned,
Thanks Mike
Old Aug 18, 2006 | 02:20 PM
SJW's Avatar
SJW
Thanks Mike
A high-res pulse failure Code 36 is almost surely caused by a fault within the optical section of the Optispark. Replacement of the Opti is the cure for that. The only other possibilities are an open connection between the Opti and the ECM on the high-res signal line, or a fault on that signal input line in the ECM itself (I've never heard of one that had such a failure, but it's possible that it could occur).
CF Member Tom Piper noted that a coil wire that's too close to the Opti harness can, in rare cases, cause anomalies on the Opti signal lines, but he also notes that the wiring harness on your '92 has a shield that the later LT1/LT4 Corvettes lack, and that this shield should prevent such an occurrence on a '92.
Check the harness between the Opti and ECM for any signs of an open circuit on the high-res signal line, and if you find nothing, there's a 99% chance that a new Opti will be the only cure.
Be well,
SJW
Old Aug 18, 2006 | 04:18 PM
mjfox's Avatar
mjfox
Default opti signal line
Which line is the opti signal line to the ecm
A low res black /red
B high res purple /white
C ignition feed yellow
D system ground black/pink
F system shield clear
anyone
know
thanks Mike
Old Aug 18, 2006 | 05:49 PM
SJW's Avatar
SJW
anyone
know
thanks Mike
Code 36 indicates a high-res signal failure. Look at the purple/white line...
Be well,
SJW
Old Aug 18, 2006 | 05:57 PM
sonomacrew01's Avatar
sonomacrew01
code 16 is the low res pulse off red/black and code 36 is purple/white.
Helms will tell you to check connections at the harness beside the intake manifold then the opti harness itself. If everything is good, bad optical sensor=bad opti.
To NO HIGH RESOLUTION PULSE FROM OPTI ,code 36 ??
