86 flickering lights FIXED
Old Sep 8, 2001 | 04:38 PM
C4TOMCAT's Avatar
C4TOMCAT
Default 86 flickering lights FIXED
Well, the problem was the alternator as some of you responded. Even though I disconnected the terminals for the first check I assume the fact it was still turning with the engine that whatever failed internally caused enough of an induced field that the wires in the engine area picked it up and magnified it..or the computer was affected by it and caused the lights to flicker. Once we took the belt off and ran without the alternator, it supported the conclusion the alternator was the problem..new one is on, and all is normal....thanks for all the responses.
