Hard Start when hot after injector change out
Old Aug 19, 2006 | 10:09 PM
sinepgib's Avatar
sinepgib
Default Hard Start when hot after injector change out
OK my 95 6spd Vert with 126k on the clock just got some upgrades and now I have a problem that doesn't make sense. When car is cold it lights @ the touch of the key. However once engine gets warm it's a little slow in starting 5-15 seconds and sometimes I smell raw fuel. Car otherwise is running like it has 26k on it.
I just would like to know if anyone else experienced similar problems I am leaning towards injector problem as that is the only real mechanical change but I would sure hope not.
Upgrades and repairs as follows
Corsa exhaust (wow it really seems to have woken the car up)
New Accel 26lb injectors (Summit racing)
A/C Delco fuel Filter
A/C Delco PCV valve
Intake oil leak repaired (used phenolic gaskets from guy on ebay)
Throttle body coolant bypassed
Trans oil changed ( nothing to do with related trouble)
Hurst Shifter install (what a bear to remove that X brace)
As always the input and feedback given on this forum is second to none.
Old Aug 19, 2006 | 10:14 PM
RRT vette's Avatar
RRT vette
Does sound like a leaky injector. I have the Accel 24 lbs and have had no problems with leaking, but have heard others dog Accel for that very reason. It is possible to have new leaky injectors. Have you pulled spark plugs to confirm a suspectious leak? Ohmed them hot and cold??
Also does it run rich??
Old Aug 19, 2006 | 10:27 PM
89vert's Avatar
89vert
Did you have it programed for the larger injectors? This could be a problem. First thing I would do is check the fuel pressure after shutting it off and make sure it's not bleeding of to quick. Just some thoughts.
Old Aug 19, 2006 | 10:42 PM
sinepgib's Avatar
sinepgib
Good Ideas I will need to check the the plugs. I actually have a new set waiting to go in so gives me an excuse to get hands cut up again. I need to get a gauge to check the pressure. Leaky injector is what I suspect also. Glad I got them from Summit they will take the return without any grief. Anyone recommend A good rebulder for the stock injectors? I would just like to get them freshened up b4 putting back in if I have to. As far as a reprogram on the computer I wasn't aware that that would or could be an issue.
Old Aug 19, 2006 | 11:15 PM
cv67's Avatar
cv67
St. Jude Donor '05
I went through two sets of new Accels before going Bosch, no problems after that. Same symptoms....Some may disagree, but toss the orginal Multecs in the trash, not worth spending money on.
Old Aug 20, 2006 | 08:44 AM
sinepgib's Avatar
sinepgib
Where did you source the Bosch injectors from? I have also heard some good things about the ford injectors. Any opion on that
Old Aug 20, 2006 | 10:52 AM
96lt4c4's Avatar
96lt4c4
A/C Delco PCV valve
I had the same problem with my 94 chevy truck after I put in a 383 with 454 injectors. The problem is your injector Base Pulse Width vs Crank. You will have to have the computer reprogramed to fix the problem. Since you have over size injectors with a stock tune the computer is dumping to much fuel when you are cranking the engine over. If you lower BPW time the engine will fire as soon as you hit the key. What this does is lowers the amount of time the injectors open when you are cranking, which means you are not dumoing as much fuel and flooding the engine.
Old Aug 20, 2006 | 11:09 AM
cv67's Avatar
cv67
St. Jude Donor '05
I got the Boschs through someone I knew that had a shop. I think most guys here use fiveomotorsports, dont have a link.
To Hard Start when hot after injector change out
