Fluctuating idle fixed
Old Sep 8, 2001 | 05:35 PM
cshuman's Avatar
cshuman
Default Fluctuating idle fixed
On occasion my idle would go up and down from 750rpm to 1100rpm and I got the check engine light. When I checked the code it was the TPS. Checked it with an OHM meter and found no problem. It did it again today and when it was at idle I found that by moving the wires at the TPS connector it would affect the idle. Got a new TPS connector and put it on at it seems to have fixed the problem. Idle is back to normal and when I move the wires at the TPS connector it does not affect it anymore. Maybe this will help others. :D
Old Sep 8, 2001 | 05:38 PM
KYVette90's Avatar
KYVette90
Default Re: Fluctuating idle fixed (cshuman)
What year is your car and where did you get a replacement connector. My connector is falling apart an I would like to replace it. Thanks. :cool:
Old Sep 9, 2001 | 09:13 AM
cshuman's Avatar
cshuman
Default Re: Fluctuating idle fixed (KYVette90)
Mines a 91 L-98. Got the replacement from Pep Boys, $11.98. Connected it using crip on insulated butt splices. Just be careful and do one wire at a time so you don't get them crossed up.
To Fluctuating idle fixed
