Alternator?
I'm assuming this is the alternator? This happened after I left my hood up for a few hours with the stupid hood lights on, which I couldn't believe would actually have drained my battery down... that and the red battery symbol on the dash makes me think it isn't the battery, it's the alternator... and the "leaving the hood up with underhood lights on" is just a coincidence.
Am I right in thinking this? If so, guess I'll have to go buy an alternator at Schuck's tomorrow. Also, is the alternator fairly easy to remove? I swapped out an alternator in my LS1 Camaro, and that was fairly easy.
Before you go buy a new one:
Check wiring first. Check that battery cable bolted on the back of the alternator is on tight.
A quick test you can do is to hold the tip of screwdriver to the back center of the alternator where the roll bearing is. If the screwdriver sticks magnetically, the alternator is producing a charge.
Also, you can connect a voltmeter across the battery with the car off and observe the voltage reading. Then with the voltmeter in place, start the car. If the voltage does not immediately jump to 13-14 volts when the engine runs, the alternator is not charging the battery.
When my alternator went south, I opted to rebuild it myself using high quality internal parts as opposed to buying a remanufactured unit of questionable quality and reliability for a much higher price.
I bought the internal parts such as the voltage regulator and brush assembly at a local alternator rebuild shop.
You might only be needing a new brush assembly.
Only problem I had was with the tensioner... it's in such a difficult spot! My '01 Camaro's tensioner was easier to get at... but still only held me up a few minutes. All in all, probably a half hour job.
