Headlight Issues on my 88
Old Aug 21, 2006 | 02:21 PM
slorance7's Avatar
slorance7
4th Gear
Default Headlight Issues on my 88
I have an 88, and my left headlight will not go up or down, the motor has been tested and it is fine. They told my it was the headlight actuator. I bought one, but now I can't find where it is located. Any help or diagrams would be greatly appreciated.
Thank you
Old Aug 21, 2006 | 02:54 PM
purplewindworm's Avatar
purplewindworm
My 1990 had a headlight problem where it would not open up or close all the way. I ended up buying the 3 delrin bushings and gear off ebay for about $20 and repaired it myself. Dealer only has the entire motor assembly ($240 or something). I ended up not needing the gear, only the bushings were bad. I used to see the 3 delrin bushings on ebay all the time for $6. I would suggest removing the entire headlight assembly ( 6 nuts, if I remember correctly) and take headlight to your work bench (diningroom table). Be sure to take a picture of it before you start to remove the motor assembly. I had forgotten how mine went back on.
Old Aug 21, 2006 | 03:17 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Sounds like bushings to me, too.
Read this article while you wait for yours to arrive after you order them.
http://www.corvettefever.com/howto/33098/
To Headlight Issues on my 88
