fuel filter
Old Aug 21, 2006 | 02:48 PM
dallasknight's Avatar
dallasknight
Default fuel filter
Could someone please tell me how man inline fuel filters the 85 has and where they are located?
Old Aug 21, 2006 | 02:59 PM
Fasterer's Avatar
Fasterer
Under car, drivers side frame rail right in front of rear tire.
Old Aug 21, 2006 | 03:14 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Pull the fuse for the fuel pump, then start the engine. Let the engine run until it starves from lack of fuel. It'll reduce the pressure in the lines considerably.
Then, (for safety's sake) disconnect the battery before you get under there and start working.
When working with fuel, you do not want to introduce a short circuit under there by sparking oh, say, the starter solenoid to the heat shield and it's so easy to do with a tool in your hand.
Old Aug 22, 2006 | 12:30 AM
goldeneye_vet's Avatar
goldeneye_vet
Sorry....passenger's side of car in location as described above. One 10mm bolt-clamp holds the fuel filter to the frame of the vehicle. Pretty easy to do and takes only a few minutes.
Old Aug 22, 2006 | 09:30 AM
RRT vette's Avatar
RRT vette
On my 86 the only fuel filter is located on the inside frame rail on the passenger side under the door. I'm not sure on a 85 though.
Old Aug 22, 2006 | 09:41 AM
zoro's Avatar
zoro
Same place, close to the front tire.
To fuel filter
