Battery Dead Overnight......?????
For starters, take the battery out and have it tested. Not just a load test, but with a test tool that will check your cells as well. Replace the battery if needed or re-charge your battery and re-install if it checks out ok. You can do a parasitic draw test to see if there's a current draw if you have a good multimeter that has a 10A, fused ammeter.
First, at night, check for underhood lights, vanity mirror lights, door panel map lights, console light. Do you have a radar detector, aftermarket alarm, aftermarket radio or audio amplifier? check em.
Buy a VOM test meter (voltmeter, ohmeter, milliammeter) so you can measure the leakage current from the battery with everything turned off. You can buy a decent VOM at www.hosfelt.com for $8.00, yes, eight dollars. Disconnect the negative cable from the battery and connect the VOM set up as an ammeter between the neg battery cable and the negative battery terminal. Pull the courtesy light fuse so you don't have to wait 30 seconds every time you pull a fuse for the courtesy lights to time out and you can keep the passenger door open without the courtesy lights on. Observe the current reading, it should be below 50 milliamps, if not, start pulling fuses one at a time and watch the ammeter to find which circuit has the excessive leakage current. If no luck with the fuses, remove the nut on the jump start terminal behind the battery and remove the 8 wires one at a time while watching the ammeter. Unplugging the alternator does not eliminate the alternator because the alternator plug gets power through the ignition switch, and if off, no current is possible. But, the alternator output wire is always connected to the battery and defective rectifier diodes in the alternator can draw current. One of the 8 wires on the jump terminal is the alternator output wire.
http://www.elkproducts.com/products/elk-blt.htm
I wonder if anything like this is made for lead acid type batteries. I'm thinking not, because they work on a different principal.
When you place an ammeter between the battery post and your disconnected battery cable, it will activate the interior lights on the timer. You'll have to keep the ammeter connected for about 20 seconds before the lights go off, which should kill most cheap multimeters. During that time, the lights will draw about 3 amps until they go out, then the current draw will reduce to whatever else is running off that circuit. This is also much easier than pulling light bulbs out from everywhere. And don't forget to unplug your under hood lights.
