Help!! A 94 ZF Vette, about 79K miles. I was driving down the freeway Saturday and went to pass a car. When I hit the gas...nothing. No power. Looked down, tach read 0 and after a sec or two the "service engine soon" light came on. Pulled off the road to take a look see. Everything appeared normal. Tried starting the car but it just turned and turned like it wasn't getting any spark or fuel (full tank of freash gas). It was strange. Car was running great then it wasn't there. No stumble or rough running, sputtering, coughing...nothing. Had to tow it back with a strap (either that or leave it for an extended period and hope the vultures don't circle to quickly). On the tow home with ignition on ASR light comes on then after a bit goes out...on/off repeatedly. Get the car home unscathed. Check for fuel at the intake. Fuel present in the rails (no pressure gauge to measure pressure with). Pull a spark plug wire no arc present. Pulled a few more...no arcing when trying to start. Removed coil and ignition control module for a test...Pass. Reinstalled coil/module. Left the hood cracked overnight (duh) needless to say, battery dead now so I can't try to flash the puter. Have to wait until battery is freash. Kinda wierd...clicking noise coming from passenger side dash with ignition off and key out. So, anyone have any ideas where I should focus my efforts next? Besides charging my battery
Car is basically stock with a few exceptions (all mods done within past 6 months):
-relocate IAT
-replace temp sending unit (195 on/175 off)
-replace thermastat (open @ 160)/hoses
-new plugs(Bosch)/wires(MSD)/coil(MSD)
-add MSD 6A
Am well aware of the "delicate" nature of the Opti. Was VERY careful not to splash around with the thermastat and hoses during change. Carefully drained system and placed a mountain of towels around the housing before I cracked it open. Not more then a drop of coolant got away.
Was hoping that flashing the puter would at least give me a general idea of where to look. However...
So, ANY ideas, input, info would be greatly appreciated.
Thanks!
Slem
