backfire off the line
Old Aug 23, 2006 | 06:17 AM
curtismoff's Avatar
curtismoff
Default backfire off the line
94 auto 21,000 if I give it more than 1/4 pedal from a stop it backfires and stumbles,any other time it's fine.anyone know any thing I can try.Please don't tell me it's the opti If it's out of gear and I rev it,it also doe's this so there does'nt have to be a load on it.
Old Aug 23, 2006 | 09:34 AM
anesthes's Avatar
anesthes
Backfires through the intake, or through the exhaust?
-- Joe
Old Aug 23, 2006 | 12:18 PM
bogus's Avatar
bogus
load dependant... that sounds like a spark related problem.
check the coil and coil wire. but at this age, the opti would not surprise me... any codes?
it could be a lack of fuel, but I would not expect a backfire from that.
considering the surprise to which this started, I would check the coil wire first.
Old Aug 23, 2006 | 01:29 PM
anesthes's Avatar
anesthes
Lean tip in pops through the intake every time. loading up, or iginition through the exhaust.. Miss-timed motor can do a little of both.
-- Joe
Old Aug 23, 2006 | 05:13 PM
rickneworleansla's Avatar
rickneworleansla
Mine backfired and ran very rough on first couple of minutes of startup. Didn't do it on WOT. Cleaning MAF solved the problem. Also you may want to check for a plug arching somewhere.
To backfire off the line
