K&N reoiling question
Old Sep 9, 2001 | 11:02 AM
PylonBoy's Avatar
PylonBoy
Default K&N reoiling question
How long after I put the oil on the filter element can I put it on and safely drive my car?
Old Sep 9, 2001 | 11:32 AM
Romeo Barrera's Avatar
Romeo Barrera
Default Re: K&N reoiling question (PylonBoy)
You should be able to drive it immediately. If you want, you could wait about 15 min to let it saturate and wick out throughout the filter, but it's not really necessary. More attention should be paid to how you clean it. Clean it with the water opposing the air filter flow or inside out. DO NOT speed up drying using a blow dryer or anything like that, just let it air dry.
Old Sep 9, 2001 | 11:50 AM
PylonBoy's Avatar
PylonBoy
Default Re: K&N reoiling question (Romeo Barrera)
so I killed it by using my 1000 degree heat gun?
j/k :D Putting it back on now.
Old Sep 9, 2001 | 02:03 PM
89convt's Avatar
89convt
Just cautionary note. I recently went through a lot of expense and diagnostics on a 96 tahoe with a K&N air filter. It turned out to be the mass air flow sensor, don't know how much truth in this but the technician at the dealership indicated that when servicing a K&N be very careful to overoiling the filter. He indicated that this can cause the maf to fail. I'm sure a main concern when servising a K&N is to be sure you have enough oil on it. Don't know if this is valid or not but I'll pass it on for what its worth., I'm running k&n on 3 different vehicles all with mafs. :confused:
To K&N reoiling question
