How do I replace the tail light bulb?
Old Sep 9, 2001 | 04:23 PM
weekendwrench's Avatar
weekendwrench
Default How do I replace the tail light bulb?
I cant reach up from underneath the car and i TRIED REMOVING THE FUEL TANL DOOR BUT CAN'T REACH THE OUTER LIGHT. Is there a way to remove the cover from the outside?
Old Sep 9, 2001 | 05:16 PM
85vetteguy's Avatar
85vetteguy
Default Re: How do I replace the tail light bulb? (weekendwrench)
Remove license plate and back up lights. Reach in and remove inner light. It is either 2 - 7mm or 10mm bolts, i cant remember the size. After removing the inner lights you can reach through the hole to the outer lights. All this to change a bulb. Nothing is easy on these cars. You can also do this through the gas door, either way it is a PIA. Good luck , Guy
[Modified by 85vetteguy, 3:18 PM 9/9/2001]
Old Sep 9, 2001 | 09:27 PM
weekendwrench
Default Re: How do I replace the tail light bulb? (85vetteguy)
Thanks! I had hoped it would be easier than that.
Old Sep 9, 2001 | 09:36 PM
Jays84Z51's Avatar
Jays84Z51
PIA is speaking lightly :smash:
Old Sep 9, 2001 | 10:32 PM
weekendwrench
It is done! This is definitely a job for someone with small arms. What a dumb design.
Old Sep 9, 2001 | 10:33 PM
J Z06's Avatar
J Z06
Ahh brilliant GM design. Thankfully I went to the LT-1 bumper. Two screws on the outside,and five minutes later the job's done. What was GM thinking when doing the L98? :rolleyes:
To How do I replace the tail light bulb?
