My uncle (C4 Dan on the forum) is having a strange problem with his '85. At times, when he first starts the car, both turn signal lights and the high bean indicator light on the dash come on. The strange thing is when it does this, the car idles really rough and wants to stall. As soon as those lights go out, the car idles perfectly smooth. I have no clue what it could be. Anyone else experience this?
Hi.
I have an 85 and had the same problem with the lights. It was not the
grounding on the engine. It was in the cluster itself. There are some connectors there with bad soldering or as time has passed the solder has dissapeaed aroung the pins. on the printed circuit board. I did as they recommended in the following site. Read through it and you will see quite clear what it might be. Here is the address:
