Noisy throwout bearing?
Old Aug 26, 2006 | 02:28 AM
jan-erik's Avatar
jan-erik
Default Noisy throwout bearing?
I ave newly changed clutch to centerforce II,
The clutch worked from nearly the bottom of the pedal. Now after about 500km the pedal warks from the midle +. The flywheel was grinded or lathed in a special flywheel lathe.
What worries me a little is that when I put the gear in neutral there is a noise coming from the clutch area when not having the clutch pedal engaged and it stops when engaging the clutch pedal.
The bearing is new and so is the bearing in the flywheel.
Old Aug 26, 2006 | 10:26 AM
any4xx's Avatar
any4xx
deleted.
