Is a torque converter something I can install myself?
Old Aug 26, 2006 | 01:59 PM
87 rag's Avatar
87 rag
Default Is a torque converter something I can install myself?
Just what the title says.
87 L98 with a new torque converter sitting in the garage gathering dust.
Is this a job anyone can do, or is it one for the pros?
I'm not a mechanic but like to tinker. I have done some work myself like catback exhaust, B&M shift improver kit, lowered the front and rear, heater core and 1.6:1 rockers with new springs and valve seals.
Is the Torque converter any harder or more technical than what I have already done?
I just hate paying someone to do something I can do myself.
Thanks.
Jeff
Old Aug 26, 2006 | 02:01 PM
vader86's Avatar
vader86
If you can do the shift kit, you should be able to do the TC.
Old Aug 26, 2006 | 02:07 PM
bogus's Avatar
bogus
Do you think you can remove the transmission? If so, go for it.
May I suggest a cheap tranny jack from Harbor Freight? Works great!
87 rag's Avatar
87 rag
It took me two attempts to get it right and a little coaching from Pete K but I got the shift kit done.
What tools would I need that I likely don't have?
Is there a tech tip anywhere that anyone knows about that would help me?
Old Aug 26, 2006 | 02:08 PM
87 rag's Avatar
87 rag
Bogus, you answered one of my questions before I asked it.
What does a cheap tranny jack cost?
Old Aug 26, 2006 | 02:27 PM
JD'S WHITE 93's Avatar
JD'S WHITE 93
I'm getting ready to do the same thing. I've been learning from Pete K as well. You can buy a transmission jack adaptor for $40.00
The adaptor works like this, you pull the saddle off your floor jack and put the trans adaptor on your jack. A flexplate/flywheel turner would be a good idea too. They only cost $25.00 and make turning the flexplate easy. A 14mm universal socket would be a good idea as well and a long extension. They make a 30" extension that is 3/8 male so you can use a smaller 3/8 drive socket on it yet the extension is 1/2 drive so you can put an impact to it or at least a big 1/2 drive ratchet.
A 9/16 line wrench would be good too. Pete K is the man that knows the transmissions, me I know tools and someday maybe I'll know how to use them all.
Old Aug 26, 2006 | 02:31 PM
JD'S WHITE 93
Do a search, tools for trans removal, Pete gives alot of good info on that thread. Or just click my name and check all threads started by me
it's recent. I would link it but I'm lucky I can turn the computer on.
Old Aug 26, 2006 | 02:37 PM
87 rag's Avatar
87 rag
Thanks, I haven't checked out your other threads yet but I will.
Sounds like I have all the tools but the adaptor for the jack and the flexplate/flywheel turner.
I'm not sure where I can get these things in Canada. Possibly Napa.
Old Aug 26, 2006 | 02:58 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Well, tell us what you don't have....
Larry
code5coupe
Old Aug 26, 2006 | 03:12 PM
87 rag's Avatar
87 rag
I don't have a henway or a set of 20 weight ball bearings.
I just meant what specialty tools will I need. I guess I should have worded it that way.
Old Aug 26, 2006 | 03:32 PM
bogus's Avatar
bogus
the tranny jack at Harbor Freight is about 50.00. It has a strap and a plate, and works like a scissors jack. Uses a 1/2" drive ratchet to raise/lower. An impact wrench is a little on the fast side.
You will want a 9/16" swivel socket with some long assed extentions for the motor to tranny bolts.
Old Aug 26, 2006 | 03:36 PM
Z06_BluByU's Avatar
Z06_BluByU
figure on spending 6-12 hours on it... 6 with a lift.. 12 without.. its not technically challenging.. its jsut having the right tools, clearance, patience and time.. its easier than the heater core!
Old Aug 26, 2006 | 03:44 PM
87 rag's Avatar
87 rag
I had to open up the heater core twice too. I knocked the little door off it's track the first time and the heat was always on.
I will look into the tranny jack.
I have plenty of extensions.
What is a 9/16" swivel socket?
How much clearance do I need? This might be the thing that stops me from doing it myself.
Thanks.
Old Aug 26, 2006 | 04:14 PM
88BlackZ-51's Avatar
88BlackZ-51
jeff looks like cayuga oct 14th or 21st. your stall we help you alot off the line.
Old Aug 26, 2006 | 04:28 PM
Vic'89's Avatar
Vic'89
The Torque convertor swap is not that big of a job.
You will need to jack the car up from the front and back.
There are no special tools needed, but a 30" - 36" 3/8 extension is needed.
The convertor has 3 bolts and the Tranny to engine has 6 bolts.
You need to remove the driveshaft and loosen the C-Beam from the back.
A Tranny jack will help , but I just used my Craftsman jack to hold the Tranny up.
Vic
Old Aug 26, 2006 | 04:33 PM
87 rag's Avatar
87 rag
Vic
Thanks Vic
What about exhaust, will it be in my way?
If I'm under there and need to take the exhaust off I should install my LT headers at the same time.
How high up does the car need to be? Will 4 jack stands do it?
Old Aug 26, 2006 | 04:48 PM
bogus's Avatar
bogus
You MUST drop the exhaust... visual will tell you if the headers are in the way.
Consider this - a TC is in the same place as the clutch on a manual...
To Is a torque converter something I can install myself?
Old Aug 26, 2006 | 04:49 PM
bogus's Avatar
bogus
I can pull a tranny in about 45 minutes now... it's not that bad. It's just getting to it.
Old Aug 26, 2006 | 05:06 PM
87 rag's Avatar
87 rag
I've always been good at taking things apart, it's puting them back together that doesn't always go so smoothly.
I may not have been clear when I mentioned the headers. They are sitting in the garage beside the torque converter also collecting dust.
It sounds like I should do both these jobs at the same time or I will be repeating steps that I only need to do once like removing the x-brace.
Old Aug 26, 2006 | 05:07 PM
87 rag's Avatar
87 rag
14th doesn't work for me but I would love to have everything swapped by the 21st.
