Help With Fuel Pressure Readings.
Old Sep 9, 2001 | 09:51 PM
olephart's Avatar
olephart
Default Help With Fuel Pressure Readings.
OK, stock LT1, runs a little rich most of the time - LT BLMs 122-124. I'm at sea level.
I hooked up a FP gauge and Here's what I got:
Before start = 41
At Idle = 38.5
At Idle with vacuum line removed = 43 (MAP was around 5 psi)
Under acceleration = 41
It was steady at each reading and never lower than 38.5. Am I testing it correctly? Are the numbers OK?
Old Sep 9, 2001 | 10:29 PM
J Z06's Avatar
J Z06
Default Re: Help With Fuel Pressure Readings. (olephart)
That sounds pretty stable.. I don't know the BLM stuff..but you sure as heck don't want the pressure to drop.
Old Sep 10, 2001 | 12:10 AM
corvette1990's Avatar
corvette1990
I finally installed the Accel fuel pressure gauge on the fuel rail, after the DYNO guy at Corvettes at Carlisle told me I was runnin rich by about 4 pounds. (11.5 air fuel ratio) He reccommended 12.5. Here is what I found. With vacumn line to AFPR disconnected/plugged. I was around 50 pounds. I backed the pressure to 46 pounds and reconnected the vacumn line and saw the pressure go to 56 with the engine running at idle. So I am concluding that the vacumn creates a higher fuel pressure. Maybe I have to try this again, and write it down. It seems to be the opposite of the original poster.
Old Sep 10, 2001 | 12:39 AM
VMAX451's Avatar
VMAX451
Sounds right, those numbers are exactly what I had on mine.
Old Sep 10, 2001 | 12:42 AM
EricVonHa's Avatar
EricVonHa
Default Re: Help With Fuel Pressure Readings. (corvette1990)
Disregard the BLM stuff... the computer will find it's happy medium only after driving the car... you'll never get it figured out by the BLM because every car is different. The BLM takes the whole system into account (basically from the O2 sensor). Standard "factory" O2 sensors vary quite a bit and are realistically only intended to determine open vs. closed loop. I would take the thing to a dyno shop and make a couple back to back runs while monitoring A/F ratio. Unlike Carlisle, to do it right, an extra bung needs to be welded into the collector of the exhaust. The readings of the dyno's wideband O2 feedback will astound you. This is the only real way to set baseline fuel pressure for max power. From there? Custom chip tuning may be able to tweak it out if you've got extreme lean/rich areas throughout portions of the RPM range.
Old Sep 10, 2001 | 11:26 AM
olephart's Avatar
olephart
Default Re: Help With Fuel Pressure Readings. (EricVonHa)
So, corvette1990 has a pressure drop with the vacuum disconected and Vince and I have an increase.
Looks like I could still use some help here.
Old Sep 10, 2001 | 11:44 AM
ZylaRace's Avatar
ZylaRace
The vacuum is used to reduce the fuel pressure in the rail under regular driving conditions (high vac). It's basic use it the power shot you get when you blip the throttle. Like an accel pump. Vaccum drops - fuel pressure increases.
Least that is how the L98 setup works. Not sure about the LT or LS engines. The reg's are different, but the app should be the same.
To Help With Fuel Pressure Readings.
