Master Cylinder Reservoir
Old Sep 9, 2001 | 10:31 PM
Skydiver's Avatar
Skydiver
Default Master Cylinder Reservoir
Has anyone changed the plastic reservoir on the master cylinder without changing the master cylinder itself? If so, where did you get the reservoir and do you have to bleed the brakes after changing it? The car is a 1987 with the single reservoir. Any help would be greatly appreciated.
Old Sep 10, 2001 | 01:11 AM
moffitt's Avatar
moffitt
Default Re: Master Cylinder Reservoir (Skydiver)
The reservoir is discontinued from GM. I had to buy a used master cylinder just to get the reservoir. No, I did not have to bleed the brakes after changing it.
