Sorry, I did not read your post well enough. When you said hatch I was thinking of the top . Yes, you may have to pull some carpet back. It's been so long long since I messed with it I can't remember. You may try having a helper push the button while you try pushing down or pulling up at the same time.
I had the same problem. Get a small pair of pliers , and open the latch, just grab the ear on the latch and open. You have to crawl in the back. Once it releases , if it don't pop out , try folding the top , like your going to store. You may have to adjust the pin, another great idea from Gm, Good luck Jim.
Do I have to remove some of the carpet to get to the latch/pin? I can't really see anything.
As far as the top goes, it's a;ready down - that's the problem, can't get the cover opened to get the top back up.
Just to a looked at mine. On the outer side of the latch mechanism there is a cable running towards the rear over the wheel well. It has a couple inches of exposed cable where it enters the latch where some pliers could grab a hold to release the latch. That is with the hatch open. I don’t see how you could ever have access with the hatch closed.
There are four flat head screws holding the brass colored latch ASM (item 8 on the second picture) that I think you could get to. With that removed it may allow you to pop the hatch. Good luck! Looks like a real pain in the ****!
Who knew - there's a manual release cable (had to dig like heck to find it though) so i was able to get her open. Once open I was able to figure out that the solinoids on each side are working so i suspect that something (the carpet I think - it looked kinda bunched up) was binding or blocking the ltach from fullly operating.
In any event - at least I won't have to drive in the rain tomorrow with my top down - I like being excentric but that looks just plain dumb.
