Tire Sizes
Old Sep 10, 2001 | 12:32 AM
khornet's Avatar
khornet
From: Phx/but its a dry blast furnace kinda heat AZ
Default Tire Sizes
Curious.... What wheel rim width size do you run on your Vette?
Old Sep 10, 2001 | 12:42 AM
khornet's Avatar
khornet
Default Re: Tire Sizes (khornet)
Sorry... screwed up on title. Should have read "Wheel Rim Sizes".
Old Sep 10, 2001 | 12:59 AM
EricVonHa's Avatar
EricVonHa
I'm running the 9.5" all the way around on my '93. I got tired of not being able to rotate the tires (somehow the back ones were always wearing much faster than the fronts) and the handling difference that the GM engineers determined would be different with an 8.5" front? No difference whatsoever! I'm happy with a modified alignment to achieve the "quicker turn-in" that a smaller contact patch tire would deliver.
Old Sep 10, 2001 | 01:25 AM
khornet's Avatar
khornet
Default Re: Tire Sizes (EricVonHa)
Running 9.5's all around requires a different alignment?
I'm getting ready to switch over to ZR-1 style rims and am trying to figure out if I should stick with the 8.5/9.5 combo or just 9.5's all around. The ability to rotate sure is incentive.
[Modified by khornet, 9:26 PM 9/9/2001]
Old Sep 10, 2001 | 11:15 PM
EricVonHa's Avatar
EricVonHa
Using 9.5" all the way 'round doesn't require a special alignment. I just mention it as the 8.5 by 9.5 factory config was supposed to allow for a crisper turn in rate with less input from the steering. This may be so, however, by changing the toe adjustment just a little out of the factory specification does the same thing. Does it wear the tires a little faster? Sure, but not a whole heck of a lot. If you go with 9.5's all the way around, you'll barely notice any difference.
Old Sep 10, 2001 | 11:21 PM
khornet's Avatar
khornet
Thanks for the clarification.
Old Sep 12, 2001 | 12:23 AM
BobMachus's Avatar
BobMachus
I still have the stock 16x8.5, and while it hurts...I am choosing to spend money on real perf mods for nw. I want to get 9.5's all around os I can rotate (unless I get enough HP that I need fatties for the back).
Bob
Old Sep 15, 2001 | 02:49 AM
gcrouse's Avatar
gcrouse
How about 11.5" fronts w/ 315s and 12.5" rears w/ 335s?
Old Sep 15, 2001 | 09:37 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Guess what one is mine? :blueangel:
Old Sep 17, 2001 | 07:57 AM
GUMPA's Avatar
GUMPA
17x9.5x56 front w/285's
17x11x50 rear with /315's :yesnod: :yesnod:
To Tire Sizes
