1/4 times
Old Aug 27, 2006 | 11:29 PM
franks96ce's Avatar
franks96ce
Default 1/4 times
for stock 96 lt1 auto. what are the 1/4 mile times. I went to the track yesterday and I hit a 14.2 in The 1/4,and the reaction time was .8172.
Old Aug 27, 2006 | 11:30 PM
vader86's Avatar
vader86
mid/upper 13s
what was your 60'?
Old Aug 27, 2006 | 11:34 PM
franks96ce's Avatar
franks96ce
my 60 was 2.2624
Old Aug 27, 2006 | 11:41 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Bring that down to a 2.0x and you've got a 13.7.
There's probably something to be gained in your shift points as well.
How quickly are you hitting full throttle in 1st?
Old Aug 27, 2006 | 11:45 PM
franks96ce's Avatar
franks96ce
Default Bring that down to a 2.0x and you've got a 13.7.
i dont want this to sound stupid but how do i do that,any suggestions
Old Aug 27, 2006 | 11:48 PM
STL94LT1's Avatar
STL94LT1
Roll into the throttle on your launch.
Old Aug 27, 2006 | 11:50 PM
franks96ce's Avatar
franks96ce
so just push the gas pedal a bit while holding the brake.
Old Aug 27, 2006 | 11:57 PM
STL94LT1's Avatar
STL94LT1
As soon as the last yellow light lights, let off the brake and roll into the throttle. Don't punch it to the floor.
Old Aug 28, 2006 | 12:06 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Well I'm going to agree with what's been said here and disagree as well.
My '93 with the stock torque converter and stock 2.59 gears has gone 13.37@102mph.
Don't worry about reaction time, it has nothing to do with the elapsed time.
I have a best 60' on street tires of 1.95.
Couple of questions:
Was ASR on or off?
Did you roll through the water box?
What kind of tires and what was the psi?
Answers:
ASR should be off, if it kicks in while you are trying to launch, it will absolutely kill your 60' time.
Go around the water, do a short dry burnout to get a little heat in the tires and a quick cleaning.
Play with tire pressures. I've had the best experience with 28 psi, but your car may be different.
Also what were the weather conditions? How hot(or cold) was the car?
What's the altitude? Just off the tops of our heads(at my track), we figure every 1000' is worth a 10th.
I try to approach the starting line with my oil at around 150 and coolant at about 165-170.
I've been able to launch by simply punching it off the line. My tires stick pretty well(Michelin Pilot XGT Z4's 285/40R17 best damn tire in the world).
Give it a try as I've described, if you were already doing that, then there has to be something wrong with the car.
Old Aug 28, 2006 | 02:10 AM
Tranzor's Avatar
Tranzor
Definitely should be more in it... in 83 degree weather with a density altitude of 2300', my '91 L98 with 2.59 gears went 14.26 @ 95.7mph. And that's with a non-too thin driver in the seat (I weigh in at 260).
The '94 LT1 A4 coupe I had went 13.83 @ 100 mph, and that was with a car that was in poor running shape (had ring blow-by, leaked a lot of oil from front & rear main seals, etc). I figure it would have been good for 13.6s or so if it was in top running order.
Of course, a lot of things play into your times that are external to your car... things like track condition, weather conditions, altitude of the track, etc.
And reaction times don't have anything to do with your ETs, as someone else mentioned. But if you're gonna race in competition at all, you'll want to get that down as well. Remember, when the 3rd yellow light comes on, foot off brake and stab the gas to the floor.
Old Aug 28, 2006 | 02:57 AM
cv67's Avatar
cv67
St. Jude Donor '05
Some good tips here, spend some more track time with the car, find out how it likes to be launched and your times will improve.
Old Aug 28, 2006 | 01:11 PM
franks96ce's Avatar
franks96ce
i have falken tires,i did go through th waterbox,and the tires were at 32psi.
Old Aug 28, 2006 | 06:39 PM
jonecap's Avatar
jonecap
Shallow stage. Just move up enough to turn the 2nd stage light on...no more. This leaves the car a few inches to move before it trips the clock. This will make a difference in your 60 foot time. My '96 manual runs 2.0 60 foot times on street tires...automatics usually have better 60 foot times than manual transmission cars.
Oh, lose the spare if you have one. Nice weight reduction = better e.t.
Old Aug 28, 2006 | 09:37 PM
redcorvettedave's Avatar
redcorvettedave
Was ASR on or off?
Answers:
Of course I'm going to agree with a man who ran 12sec
in a stock LT1......also put trans in "D"....not overdrive
Old Aug 28, 2006 | 09:46 PM
Mr Mojo's Avatar
Mr Mojo
Thank you, and yes, be sure to have it in "D"(3rd) not "OD"(4th).
Play with the tire pressures, go around the water, I will assume you spun pretty bad. Without a spin, you can shave off 2 tenths from your 60'.
Here are a couple videos to show you the difference between a good launch and a bad launch.
good launch, the tire screech you hear is from the C5
If you look at what I ran and what my dial is on the next video, I would have definitely ran that number had I not spun.
http://temp.corvetteforum.net/c4/mrm...ojovsmoose.wmv
bad launch, my tire spin at the line cost me the race. If you listen to the announcer, you can hear him say the winner had a bad reaction time but won because I didn't run the number.
http://temp.corvetteforum.net/c4/mrmojo2//bracket1.wmv
This one shows a just about perfect launch(in my six speed)
http://temp.corvetteforum.net/c4/mrm...ovspanuzzo.wmv
This is in my automatic, shows you what a good set of tires and a gear swap can do for you.(check the 60' on teh clock as I drive by)
http://temp.corvetteforum.net/c4/mrm...mov01484-1.wmv
Old Aug 28, 2006 | 10:49 PM
Tranzor's Avatar
Tranzor
I don't think it really matters if you're in D or "OD"... the car wouldn't ever shift into OD in the short amount of time it takes you to get down the quarter mile.
I personally noticed no difference between the two... my car ran within 5 hundredths of a second on six different runs on the same day, and at least 1 or 2 of those were in "D" instead of "OD".
Old Aug 29, 2006 | 07:30 AM
Mr Mojo's Avatar
Mr Mojo
It makes a whopping difference if you are bracket racing.
To 1/4 times
