I understand the 170 degree stat must be carefully matched to header size to avoid coolant flow resonance, when using Dex-cool galvanic action can create RFI interferance that raises havoc with the Opti, Hypertech is developing a special chip to compensate for such problems.
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Just make sure and use only Zaino on your X pipe and all will be well.....
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Originally Posted by loiq
If you install a mini ram you'll lose all your torque.
That's okay, because as long as you have oil pressure, the oil pressure switch will keep power to the rear wheels, assuming you haven't put 18s on there and completely screwed up your speedometer.
