Rear main seal (93 LT1) replace while doing clutch?
Old Aug 28, 2006 | 04:02 PM
dizwiz24's Avatar
dizwiz24
Default Rear main seal (93 LT1) replace while doing clutch?
Im gathering the parts to do my clutch change. Last time I replaced the clutch (in 2002, a mere 25k ago) I replaced the rear main seal as well.
I took off the flywheel (aluminum flywheel with steel friction plate) and noted that there are a few drops of oil off the rear main seal. These may not necessarily be due to a faulty seal, but may be due to the fact the engine is tilted back slightly and all the oil is now up against the rear main seal.
There was also a tiny amount of oil on the front bellhousing cover (that sheet metal that bolts to the bottom half of the bellhousing).
Since my timing cover leaks a tiny amount of oil, its possible it could have blown back while driving onto the bellhousing. The underside of the oil pan has a slight misting of oil on it.
Keep in mind, my car doesnt leak any drops of oil on the ground. Its just that a light misting of oil develops around the timing cover.
Do you guys usually replace the rear main seal when doing a clutch change?
Any advice is appreciated.
Old Aug 28, 2006 | 04:10 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Couldn't hurt, I did. I think the GM seal was $20.
Old Aug 28, 2006 | 04:51 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
No, VERIFY where it is coming from and then fix. Do not through your money away, unless you are Bill Gates. A rear seal should last along time, when I thought mine was bad, turned out to be a leaking valve cover gasket.
Old Aug 29, 2006 | 02:51 PM
Robey5's Avatar
Robey5
Ugh. 25k miles on one clutch? Wow.
I may be changing my centerforce pressure plate and friction disk back to my original, becuse I am not crazy about the sounds and noises my centerforce makes.
Anyhow, I would not replace the rear main, unless you are SURE that you have a leak there. Could do more harm than good. Just my .02
Old Aug 29, 2006 | 06:42 PM
hip's Avatar
hip
The 1 piece seal is a PITA to replace but if it needs it it doesn't inprove with time
Old Aug 29, 2006 | 07:14 PM
Marine_Marauder's Avatar
Marine_Marauder
Old Aug 29, 2006 | 08:31 PM
JTHVETTE's Avatar
JTHVETTE
Default Replacing 1-pc Rear Seal
It is not hard at all. What I have found that works very well is put two 3" drywall screws into the seal's outer edge, opposite of each other.(just deep enough to get a good bite) Then take a claw hammer and pry the seal out. This might seem crude, but it works. When installing the new seal, use the plastic guide that is provided.
MY 2 cents,
JTHVETTE
Old Aug 29, 2006 | 11:02 PM
DVNCI's Avatar
DVNCI
MY 2 cents,
JTHVETTE
Bought a higher end FelPro seal from Summit that came with a plastic guide.
Make sure to clean the mating surface on the engine well. Mine had some gunk on it and I think that is why it was leaking a little. I cleaned it off with some brake cleaner (or choose your favorite solvent) so it was spotless before the seal went on. Not a drop since.
To Rear main seal (93 LT1) replace while doing clutch?
