Transmission question
Old Aug 29, 2006 | 12:00 AM
ahearrean's Avatar
ahearrean
5th Gear
Default Transmission question
I am rebuilding my LT1 and wanted to know if I should go ahead and have the tranny looked at. It is an automatic with about 130k on it. I have not had any problems with it but since I do not want any I thought this might be a good time to check it out. What kind of stuff should I look for to tell the tranny guy.
Old Aug 29, 2006 | 12:54 AM
96lastc4's Avatar
96lastc4
Hi
I do not have a good answer to your question. I think they are going to want to know if you are upgrading heads or cam etc. this will play a part in their answer.
Old Aug 29, 2006 | 01:08 AM
ahearrean's Avatar
ahearrean
5th Gear
I'm going back stock on everything. I think I read somewhere here about others having trouble with there tranny after 100k
Old Aug 29, 2006 | 01:14 AM
Maui's Avatar
Maui
St. Jude Donor '08
If you're going to rebuild the motor you might as well have the tranny rebuilt. I certainly wouldn't match a tranny with 130k up to a new motor. Shouldn't run you more than a few hundred bucks and save you from having to pull it out later.
Old Aug 29, 2006 | 01:31 AM
96lastc4's Avatar
96lastc4
Old Aug 29, 2006 | 07:01 AM
Pete K's Avatar
Pete K
Even though I build my own transmissions, I would not fix mine unless it was broken. The late model units (94-96) seem to last much longer than the non electronic versions. No tv system or governor to cause problems.
To Transmission question
