Differences in carpet
Old Aug 29, 2006 | 08:51 AM
Thrak's Avatar
Thrak
Default Differences in carpet
I'm about to order a full carpet set for my 85 and was wondering what the "real world" difference is between the mass back and poly back. (other than $100)
If I'm not doing a factory correct restor and just want new carpet is the poly back that bad? I'm also putting dynamat extreme in that will dampen sound and reduce heat...
Where is the best/cheapest place to buy good carpet? Ecklers? One of the sponsors?
Thanks guys!
Old Aug 29, 2006 | 09:37 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Don't know the answer to cheapest/best, sponsor or not, but if you're not doing a factory resto job, you're right, why bother spending big (or bigger) bucks?
It's a good question though as to whether the less expensive stuff (compared cheaper which implies cheaply made) will break down easily or wear out, fade, etc. That's a good one to have answered since all colors fade, get stained, abrasion, etc.
Let's see who responds altho this might even be a good question for the car care section???//
Old Aug 29, 2006 | 09:41 AM
Sam Lam's Avatar
Sam Lam
I bought the carpet for my 89 from Wilcox. The carpet fit very well. However, some trimming was involved. I got the mass back as I thought this had a thicker pad and would reduce road noise in the interior of the car. Just my thoughts on the above thread.
Old Aug 29, 2006 | 10:29 AM
72C20's Avatar
72C20
7th Gear
I bought a carpet set for my 85 from Mid America with the mass back. the side panel carpet pieces are poly back. There is a big difference. The carpet fit well with minor trimming. In my opinion I would go with the mass back.
Old Aug 29, 2006 | 11:42 AM
jimmers's Avatar
jimmers
Get the mass backing. It fits way better and its like the original!
Old Aug 29, 2006 | 01:14 PM
Thrak's Avatar
Thrak
How big a difference are we talking about though? Is it heat or noise? Is it really $100 worth? What is the difference?
You say fit is way better, but how bad is the poly fit? Is it absolutely horrible?
Old Aug 29, 2006 | 04:48 PM
jimmers's Avatar
jimmers
The mass backing is thicker so yes it would keep heat and the noise down more then the poly back. I don't know exact numbers thou. If your going to replace the carpet your best off to put some sort of sound/heat material under the carpet for added noise and heat reduction.
Old Aug 29, 2006 | 06:38 PM
hip's Avatar
hip
Default Wilcox
I got my carpet from Wilcox, which is Auto Custom Carpet, the same brand you get from: Ecklers, mid america, GM, ect. only about a $100 cheaper, you can get it through Wilcox than you can from ACC. I allso got my weatherstriping & door panels from them, & am very pleased. If a body shop wants to charge $100 to do the weather striping it's well spent money.With the garpetting I would buy the heat shielding, the carpet is a complete set so their is some glueing & slow work if you've never done it
Old Aug 30, 2006 | 08:37 AM
Thrak's Avatar
Thrak
AWESOME!! Wilcox has the mass back full car set for $400 !!! Now I dont have to worry about saving the money... I can get the best and a great price! Thanks man!!
Old Aug 30, 2006 | 10:36 AM
Joe C's Avatar
Joe C
wilcox here - mass back -
Old Aug 30, 2006 | 11:30 PM
pletzvet's Avatar
pletzvet
Wilcox was the best deal for me here in Canada and they were great to deal with too. I choose the mass back and am very pleased with the fit
Old Aug 31, 2006 | 12:16 AM
5pinball's Avatar
5pinball
i put polyback from vETTE central in wifes 88 cpe 3 or 4 yrs ago . no niticeable dif in heat or sound(stock mufflers} she drives it 7to 10 mo. of the yr and its held up well
Old Oct 29, 2006 | 10:21 PM
quicktsi's Avatar
quicktsi
Sorry for the stupid question. I keep reading poly or mass backing? When I pulled the rear carpet today I made an observation. Under the carpet there was padding. Is this padding what people call mass or poly backed? I am thinking this is correct. I just want to make sure before throwing it away.
Old Oct 29, 2006 | 10:34 PM
Thrak's Avatar
Thrak
no, thats just carpet padding... the mass backing is bascially what the carpet is "mounted" to. Its still rubber type stuff thats moulded to fit..
btw, the WILCOX stuff is great!
Old Oct 30, 2006 | 06:06 AM
Joe C's Avatar
Joe C
...just to correct everyone, INCLUDING MYSELF, its Willcox (2 L's), not Wilcox -
Old Oct 30, 2006 | 08:18 AM
quicktsi's Avatar
quicktsi
So don't throw away the carpet padding?
Old Oct 30, 2006 | 08:24 AM
Bob CTS's Avatar
Bob CTS
Old Oct 30, 2006 | 04:37 PM
Thrak's Avatar
Thrak
My padding was all nasty, so I threw all that out and went to home depot and got like 12sq.ft for $5 or so... dont need anything fancy under there.
To Differences in carpet
