Manul Fan Switch!!
Old Sep 10, 2001 | 11:07 AM
93vetteguy's Avatar
93vetteguy
Default Manul Fan Switch!!
Where can I get one and how to hook it up? I read about a guy in the forum ordering one from a catalog, but I do not know where. Can I just buy the hardware and make one myself. :cool:
Old Sep 10, 2001 | 02:14 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Manul Fan Switch!! (93vetteguy)
You just need to locate the fans relay input contacts and wire a switch in parallel with the same contact that the ECM grounds to turn on the fan.
Old Sep 10, 2001 | 05:54 PM
jiml94's Avatar
jiml94
Go to Eckler's or Mid America Design Catalogs They are in there for about $13.. You can also do your own with parts from RadioShack. See tip section in this forum on how to connect. Go behind battery and there is a bung hole thru the firewall where you can run your wires. Easier than trying the other recommended place.
[Modified by jiml94, 3:56 PM 9/10/2001]
To Manul Fan Switch!!
