Getting High RPM Knock.
a) 94 Sunoco fuel all the time
b) New Plugs
c) New MSD 8.5mm Wires
d) Stock Distributor/Cap/Rotor/Coil (as far as I know)
e) Initial Timing at 6 degrees
f) Hypertech Stage II EPROM
...it is happening over 3500 RPM, and the tach is also fluctuating pretty good at the same time while it's occurring. Where should I start?
He suggested removing the Hypertech, putting my stock EPROM back in, and just upping the timing a bit on my own since the Hypertech basically only ups the timing curve in the lower RPM and turns the fans on sooner. I already have a fan override switch, so i can turn them on at will.All ideas welcome, thanks.
Maybe if I time it right, the next time I go to the strip I can get 1/2 tank or something.
Make sure none of your wires are arcing. How's the fuel pressure at WOT ?
Vic
I'm not suggesting that you do this all of the time - just to see if you get rid of all of the knock. Make sure it's unleaded.
You really need a scanner to track the problem down. I suspect you have good plugs and wiring and no carbon deposits. I don't remember your compression ratio, but that may be part of it.
Some other common causes:
Bad Gas - it happens.
Running Lean - vacuum leaks, fuel pressure, bad injector (s).
High Temperature - IAT as well as H20.
Maybe a little bit of all of the above. Finding the problem can be tough.
I would agree with ditching the programming until the problem is resolved.
Here is the formula to figure out your octane when blending:
Gallons of old gas X octane = product 1
Gallons of new gas X octane = product 2
Sum of products / sum of gallons = blended octane.
Example with 10 gallons of 92 blended with 2 gallons of 110:
10 X 92 = 920
2 X 110 = 220
1140/12 = 95
Good luck, it's driving me crazy.
You need some scanner data to find out what's up inside.
Does it happen only at WOT or only above 3,500 RPM?
If you back base timing off say 5-6 deg does it change (decrease)?
Is everything tight inside the dist cap?
