Headgaskets and Nitrous
It is usually 1 1/2 deg timing for every 50 shot.
You were probely holding the nitrous for more than 15 seconds .
You should be using the copper gaskets or feld pro.Check your compression when replacing the plugs and see if any cylenders are below 10% of the rest before you use the nitrous.
Head gaskets are not something that usually blows first on a nitrous motor.The plugs usually burn the electrode.
A better spark is always good.
I use the msd dial on mine to retard the timing when I fire the juice.
Never use water in the radiator.I use distilled or coolent.
I think you had a head gasket problem and the nitrous just finished it off.
Stock components in the rotating assembly. Stock crank, rods, a small overbore, and stock replacement pistons.
Aftermarket cam of unknown specs.
Computer tune of unknown origin, with an unknown amount of timing advance.
My bet, is that some detonation or maybe even pre-ignition caused your failure. With a 150 shot, you should be pulling at least 3 degrees of timing off the stock tune, 5 or 6 would be safer. You might need to pull even more timing depending on the timing advance in the computer re-tune that was done for the cam.
Depending on cam specs, your dynamic compression ratio can also be really high. It's possible that with the right cam, and a 150 shot you just over powered the head gaskets with an extreme amount of cylinder pressure. Peak cylinder pressure needs to occur as close to 14 degrees ATDC as possible. Without knowing the cam specs and timing advance, it's impossible for us to even guess at where peak pressure is occurring. Since the engine was making good power, we can assume you are somewhere close to the 14 degree ATDC optimum, but we don't know for sure. If you were making peak pressure at say, 10 degrees ATDC, then it's not really the head gaskets fault that it let go. You could theoretically run the same head gaskets again, move peak pressure to 14 degrees ATDC, and be just fine. If you were making peak pressure at 14 degrees ATDC, then it is possible that you just over powered the head gaskets. If that's the case you'd need some better head gaskets, to go to head studs, or some other better method of sealing.
Like I said though, my bet is that too much timing contributed to a detonation problem, and that is what caused the gaskets to let go.
and if you are ever unsure of the timing or just would like a little security, don't hesistate to use a race fuel 50/50 mix. I never pulled timing on my 5.0s or 360mag, 100 shot with 50/50 mix. Since you are running 150 I tend to agree with a few degress of timing removed. Also make sure you get those plugs dropped a range or two. Heat kills.
If alum I would install B8EFS NGK plugs .
The plugs are fine for all my driving condtions and I have had no problems.
Do you have an adjustable reg?
You could get an aftermarket ignition box like a Mallory, MSD, Crane, etc... These boxes will allow you to run your full timing advance for notmal driving, and then when you arm the nitrous system the box pulls a set number of degrees of timing. I have a Mallory 685 and really like it. It's got a built in window switch to turn the N20 on and off, automatic timing retard that is adjustable in .1 degree increments, N20 shut down 500 RPM's before the rev-limiter, and all kinds of other N20 friendly features. The cheapest place I've ever found it is www.centuryperformance.com.
A colder plug won't affect driveability at all, but they do tend to foul a little quicker, especially if the engine is running rich at all.
Good luck, and get some timing out of that sucker!
The plugs I gap at 32.You should not have a problem fouling the plugs you are not pulling enough timing .When I pull 6 degrees or more then you can see the sparks fly.
I highly recomend that you run Nitrous fuel addative,3 ounces per 3 gallons of fuel.You should always regardless of what any one says try to increase the burn time on the fuel.
106 is good if you want peek performance.
Your trans will last longer if you have a button and shoot above 3000 rpm's and shut off 500 rpms before the trans shifts.
Make sure you bottle presure is always around 87 to 90 degrees after your first shot.presure should be around 950 psito 1000psi.
Pulling fuel pressure is a bad idea at this point, in my opinion. Lean, and nitrous are a bad combination. He might have a failing fuel pump, clogged fuel filter, stuck injectors, or any of a hundred other issues where that extra fuel is what is keeping his engine alive. Pulling fuel, without knowing what his AF ratio is at WOT, is a bad idea right now I think. If he could get the car on a dyno with a wideband and spray it, then he could make changes based on that, but I don't think just dropping fuel pressure based on ??? is a really good idea.
http://www.go-fast.org/z28/new_to_nitrous.html
http://www.robietherobot.com/NitrousJetCalculator.htm
If you want more info I have lots.
Making mistakes with nitrous can be many ,you just want to keep them
to a minium.
Explosions and engine problems with nitrous can usually lead to something the person did wrong .Their are exceptions like NX and their junk solenoids.
They build them in house now?so they say.
Yes I put it back together it is the silver /blue vet in my sig.
I use 106 race non leaded race fuel in my red corvette and a 125 shot.
On the B/S vet 300 shot and C17 or C16 race fuel.I run almost 15 to 1 compression.
