Last year I lowered my vette with new bolts from Ecklers. Now should it be the tighter the bolt the lower the car. Right now I only have a few threads left before the bolt falls off. Is that as low as it goes. im just having a really bad brain fart. Thank's
To lower the car further you want to loosen the nut or make the bolt longer.
I you want to go a little lower than the bolts will permit, you can also move all of the shims at the sping mounts where the spring is attached to the batwing to the bottom of the spring.
This will raise the spring with respect to the rest of the car.
