Terrible pinging at operating temperature
Old Sep 16, 2006 | 08:53 AM
  #101
Casethecorvetteman's Avatar
Casethecorvetteman
Originally Posted by CFI-EFI
You may be right. It is hard to be sure the way it is written,
I assumed an "and" after, "short block". You are saying to assume a "with". It could have been more clearly written.
RACE ON!!!
Yeah mate, i can see where you could get confused, i only took a guess based on what his sig says myself
Old Sep 16, 2006 | 06:35 PM
  #102
edcmat-l1's Avatar
edcmat-l1
I said it first, that the compression ratio is the lesser factor in the cranking pressure,
RACE ON!!!
I agree completely. this is why we dont put alot of value in the actual #s, more in HOW it makes compression. All the motors we build have the compression calculated very accurately. To me its more important than degreeing a cam. Actually now that i think about it, its probably the most important check. how can you build someone a motor, especially if its not one that you do everyday, and not check the compression accurately?
