engine problem
Old Aug 30, 2006 | 05:51 PM
8888vette's Avatar
8888vette
Default engine problem
Guys ;
i drove my car last friday all fine today i started the car and its running rough on idle and if you drive it under load it will stumble and i lost engine power
any help appreciated
Old Aug 30, 2006 | 06:12 PM
Aardwolf's Avatar
Aardwolf
Any codes?
Old Aug 30, 2006 | 06:37 PM
ken863's Avatar
ken863
Cruising
I had the same problem. It turned out to be 4 of the 8 orginal injectors were bad.
Ken
Old Aug 31, 2006 | 08:48 AM
8888vette's Avatar
8888vette
my vettte has open air lid and flow master exhaust and there is no codes i did change the fuel filter last night and this morning it start it right up the it died after several times finally staid running but the same no power i can feel the engine shake under load still crapy ........i do have fuel coming out of the rail
what should be my next step a shop or can i do anything on my own
friday it was running perfect 5 days later like crap
Old Aug 31, 2006 | 08:53 AM
Clay Assassin's Avatar
Clay Assassin
start checking the injectors.
Old Aug 31, 2006 | 10:23 AM
CFI-EFI's Avatar
CFI-EFI
Air, fuel, spark and compression. You need all of them in the right amount, at the right time. What is missing, or inadequate? Check the trouble shooting charts in your FSM. Otherwise I would start with checking the fuel pressure.
RACE ON!!!
Old Aug 31, 2006 | 10:55 AM
purplewindworm's Avatar
purplewindworm
Over 100K miles? Change timing chain.
Old Aug 31, 2006 | 10:57 AM
runner140*'s Avatar
runner140*
Is it possible you put the fuel filter with the arrow pointing toward the rear?
Old Aug 31, 2006 | 11:40 AM
8888vette's Avatar
8888vette
the problem was there before i change the filter it would start but not run wright then it wold not run at all i decided to change the filter i did make sure the filter is facing the right way the engine fired up after a couple of tries but still running sluggish 90,000 miles
Old Aug 31, 2006 | 11:45 AM
8888vette's Avatar
8888vette
this morning it stated wright up the it died after 2 tries if fired up but running rough and under load it fills like lack of power
Old Aug 31, 2006 | 03:24 PM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
RACE ON!!!
A fuel pressure check is a good first place to start. If you have an 88, the open your bible, (FSM) to the book of "Driveability and Emmissions" page 6E3-1, and read from the letters of Paul to the Corinthians, i.e. "Section B - Symptoms".
Old Aug 31, 2006 | 07:39 PM
8888vette's Avatar
8888vette
Default code 22
i pull the codes with a pin so the only thing o got after code 12 was 2 flashes followed by 2 other flashes
Old Aug 31, 2006 | 07:54 PM
CFI-EFI's Avatar
CFI-EFI
So code "12" flashed 3 times, right? Then code "22" flashed... three times? What came after the third "22"? With the NEW information on the codes, skip my advice on checking the fuel pressure, first. Go straight to the FSM and follow the trouble shooting chart for code 22, and any other codes that followed the "22".
RACE ON!!!
Old Aug 31, 2006 | 08:12 PM
8888vette's Avatar
8888vette
Default code 22
RACE ON!!!
the only code i got was 22 no other i would need to by and fsm knowing this is my first problem with my car after almost 1 year
Old Aug 31, 2006 | 08:42 PM
CFI-EFI's Avatar
CFI-EFI
At the risk of repeating myself, "What came after the third "22"?".
If "need to by and fsm" means that you have to purchase a Factory Service Manual, than by all means, do. Make sure it is the FACTORY manual published by Helm Inc, as per the links both Mike_88Z51 and I provided. A generic manual, such as from Chilton, Haynes, or any others won't have the trouble shooting charts you are going to so badly need.
Old Sep 1, 2006 | 11:23 AM
purplewindworm
FSM all the way!!
Old Sep 1, 2006 | 02:16 PM
Mike_88Z51's Avatar
Mike_88Z51
A code 22 is Throttle Position Sensor (TPS) - signal voltage low. You need to check for a defective TPS sensor or corrosion in the TPS circuit. It could be a simple loose wire giong into the TPS, some corrosion in the TPS connetors, or a loose TPS adjustment screw. You'll need a multi-meter to measure voltage in the 0-10v range and something to loosen the TPS sensor on the side of the throttle body.
As CFI-EFI says, having a Helms FSM would allow you to go directly to the Code 22 troubleshooting chart so you want to buy one as soon as possible. Sometmes they can be had used on eBay or the CF For Sale Forum at a significant savings. Agent 86 has PDF copies of many manual pages. He may have the chart you need in a downloadable file.
To engine problem
