Will a complete 86 engine work in an 89??
Old Aug 30, 2006 | 10:15 PM
RichardL's Avatar
RichardL
Default Will a complete 86 engine work in an 89??
I have an opertunity to purchase a modified engine that was in an 86 corvette for a very short time. It is complete with all sensors, throttle body, everything just as it was pulled out of the 86. Will it work in my 89? Could I be so lucky as to only need a new chip for my computer? I know that there were a lot of differences in the 89 parts compared to the 86. Buy would everything just plug in and work? I am sure I would not be that lucky. I don't have much time to decide if I want this engine. Please give me your thoughts.
Richard
Old Aug 30, 2006 | 10:20 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
It will bolt right in...theyre all one piece rear seal after 86.
Old Aug 30, 2006 | 11:55 PM
JAKE's Avatar
JAKE
The only thing I can think of that's significantly different is the cold start injector programming in the PROM.
In 89, GM went away from the 9th (Cold Start Injector) and went with the cold startup mixture programmed in the PROM.
Not a problem though. Simply disable the cold start injector on your 86 and have your PROM re-burned to give the richer startup fuel. Alvin at PCMFORLESS, who is a Forum sponsor, can do it for you.
If you 86 is an early model - iron heads, then you may need Alvin to tweak the PROM to account for that too. Email him and he'll tell you all that's needed.
Eveything else should bolt right up.
Jake
Old Aug 30, 2006 | 11:58 PM
Demonic85's Avatar
Demonic85
Any L98 will work, programming the prom is all thats required.
Old Aug 31, 2006 | 01:33 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Why don't you just reuse your 89 harness and sensors on the 86 motor?
Old Aug 31, 2006 | 05:57 AM
RichardL's Avatar
RichardL
I would plan to use my 89 harness. But I didn't know what sensors would be different on the 86 engine that would need to be changed.
Thanks everyone. It looks like it should fit better then I thought.
Richard
Old Aug 31, 2006 | 07:47 AM
USAsOnlyWay's Avatar
USAsOnlyWay
I think it should be pretty much plug and play...before you go tearing harnasses out just look it over. There are only a couple on the block, my bet is everything will hook right up. (Only exception being possible the IAC valve under the TB and the MAF sensor (if included) because I believe yours is MAP, in which case just keep yours and continue with the plug and play)
Old Sep 1, 2006 | 06:19 AM
RichardL's Avatar
RichardL
Thanks to everyone that responded. It sounds like it should work with some minor changes. I will try and contact the guy this weekend.
Richard
To Will a complete 86 engine work in an 89??
