Theory on drone (resonance)
I think the merging of the two exhaust banks is the source of the drone. Mustang 5.0 guys also struggle with drone because they also have merged exhaust (h-pipe). Now this goes against the held theory the merging the two exhaust streams supposedly quiets the exhaust. The only reason pulling cats increases drone is because they act as additonal sound suppression. Has anybody run true duals on a C4 and noticed the disappearance of drone? Any thoughts?
Have you ever heard a helicopter fly? It makes that wack-wack-wack sound. Or a high performance prop-driven airplane? The roar off the props? Well, in both cases, the sound is caused by the tips of the respective props breaking the speed of sound.
Something similar is happening within the L98 exhaust system. It is the torture of the air flow. It bends in tightly, it gets squeezed together in bad ways, then ripped apart in even worse ways.
In short, it's restriction. The air is being compressed, essentially.
The LT1 OEM exhaust is prone to droning, but no where NEAR as bad as the L98 OEM. The LT1 OEM is dual, with an h-pipe, IIRC... and I think the resonator is a common chamber, too.
The key here is the tuning... and I honestly beleive that GM got in over their heads with the L98 system, and couldn't get out. That us, until the ZR1 and then LT1. They both use dual cats and dual exhaust. That collision never occurs.
If you live in an area that is less emissions restrictive, convert over to an LT1 style exhaust... dual bullet cats, where the precats are, then mount up an LT1 system, be it Corsa or what not... you will gain 20+hp, I will bet, and will be quieter for it.
then again, the Corsa system is well tuned, and will get rid of the drone, too. I haven't heard it in an L98 yet, but I bet it works good.
GM puts things there for the stock car, once you start changing it all then you've screwed up their engineering that went into it (as little as GM does) and you have to figure it out yourself. X pipes, resonators, special mufflers and such can either increase drone or kill it altogether.
I hated the drone in my 90 until today. It has a stock exhaust with the exception of the mufflers, they are aftermark.
All that said, if you don't like the drone I recommend you read this post:
http://forums.corvetteforum.com/show...ight=resonance
I did the same procedure on my mufflers and man what a difference. The drone at 1700 rpm is completely gone. I don't know what brand mufflers I have but here is what they look like with the plug in.
