Cam Break-In Question
Old Aug 31, 2006 | 12:55 PM
90Indy's Avatar
90Indy
Default Cam Break-In Question
If you install a new cam and do not properly break it in and some of the lobes go flat, what would the symtom(s) be?
Thanks,
90Indy
Old Aug 31, 2006 | 01:07 PM
STL94LT1's Avatar
STL94LT1
Is it a roller camshaft? If so, there is no break-in period.
Old Aug 31, 2006 | 01:08 PM
90Indy's Avatar
90Indy
No, flat tappet.
90Indy
Old Aug 31, 2006 | 01:31 PM
CFI-EFI's Avatar
CFI-EFI
If a lobe goes totally flat, that valve won't open. Any loss of the lobe, reduces the valve lift by the loss of the lobe, times the rocker (1.50?)ratio.
RACE ON!!!
Old Aug 31, 2006 | 02:00 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
Depending on the wear to the lobe(s), the engine would run very rough, like it was only on 4 or 5 cylinders.
Old Aug 31, 2006 | 02:05 PM
redrose's Avatar
redrose
backfires, runs rough, low power
Old Aug 31, 2006 | 02:40 PM
GeosFun's Avatar
GeosFun
Backfires sound like the ignition is firing a cylinder when the exhaust valve is still open. Cam going flat should not cause that
Old Aug 31, 2006 | 02:48 PM
kalister1's Avatar
kalister1
Would that cause a tap?
Old Aug 31, 2006 | 03:19 PM
90Indy's Avatar
90Indy
I was thinking the valve on the bad lobe would begin to make noise due to the decreased preload.
90Indy
Old Aug 31, 2006 | 04:41 PM
fredk's Avatar
fredk
I lost a lobe in a Camaro and it went rat tap tat or a tap tat tap.
Fred
Old Aug 31, 2006 | 05:00 PM
hippy's Avatar
hippy
Loss of power, backfiring thru the intake. Pull the valve covers and watch to see if the valves are moving, pretty simple.
Old Aug 31, 2006 | 07:45 PM
CFI-EFI's Avatar
CFI-EFI
The only way an engine will back fire though the intake is if an intake valve is OPEN when the cylinder fires. A worn cam causes the valves to not open enough, not too much, or at the wrong time.
90Indy
More or less preload doesn't make any difference in the noise under normal conditions. But when a lobe goes away, not only does the preload disappear, clearance is introduced to the valve train for that (those) cylinder(s), which DOES make noise.
RACE ON!!!
Old Aug 31, 2006 | 08:45 PM
cv67's Avatar
cv67
St. Jude Donor '05
Yes, especially after adjusting it and it comes back. When it gets really bad it can pop back thorught the intake tract as you accelerate, cant miss it.
Old Aug 31, 2006 | 08:57 PM
CFI-EFI's Avatar
CFI-EFI
I guess it could pop back through the intake, if it is an exhaust valve that doesn't open.
RACE ON!!!
Old Aug 31, 2006 | 09:03 PM
cv67's Avatar
cv67
St. Jude Donor '05
RACE ON!!!
Had that happen on both a 401 SST Javelin and a 67 Caprice. Sounded like some chickens clucking under the hood.
To Cam Break-In Question
